Good thing you’re not a coach because no one improves with a fixed mindset.
Tim
Hah you couldn’t be more wrong about me. I grind it out BECAUSE I don’t have a fixed mindset. But I’m also realistic - after yeras of this, you’re going to hit massively diminishing returns. Which is exactly what LS and SL are running into. I’m nowhere near as good as them so I def have more on the table, but given my 15-20k/wk training load, it’s about as good as it’s going to get with the bike-run that I’m also doing. That’s not defeatist, its just realistic. Doesn’t mean I dont try and eke out every gain out of every stroke, and I mix it up regularly to make sure I’m not in a training rut.
I just don’t conflate make small, sometimes miniscule gains, vs race-changing gains. And yes, I’m aware that all the miniscule gains CAN add up to a big one. I’m unfortunately still betting against that happening in the seasoned case of LS and less so in the case of SL. I do hope I’m wrong, but clearly other really good swim coaches haven’t been able to help him make that jump, so it seems more likely than not that this will be the case for them.
Do you actually swim 20 k per week? Why? Unless you are at these guys level or higher, I really think most of us regardless of talent could get away with 6-10 k and still be in ~22 min 1500 LCM shape. Quality over quantity is a better. mindset.
