I have two bikes for sale, have had them on ebay and craigslist but thought I should post here too:
Moots Vamoots DR 55cm Fresh New Build R7020 - $5250 shipped or $5000 local pickup in Boulder
more pictures here: Moots Vamoots DR 55cm Fresh New Build R7020 - bicycles - by owner -... (craigslist.org)
2018 Moots Vamoots DR 55cm frameset in excellent condition with a FRESH NEW BUILD! The Vamoots DR features straight gauge titanium tubing and clearance for 30mm tires for an ultra smooth and sprightly ride. This bike rides beautifully and features modern features like flat mount disc brakes and thru axles but retains some classic elements with exposed shift cables and looped housing guides for the rear brake hose.
https://moots.com/...ull-love-vamoots-dr/
The bike has a brand new Shimano R7020 11 speed mechanical/hydraulic build, brand new Shimano RS710 C46 tubeless carbon wheelset with Panaracer Agilest TLR 28mm tires, Whisky alloy bar/stem and carbon seatpost, Fizik Titanio saddle, and a Chris King inset headset.
FULL SPEC:
Frameset: 2018 Moots Vamoots DR 55cm, Moots full carbon road fork, Chris King Inset Headset, mechanical shifting, flat mount brakes, 12mm x 100mm front, 142mm rear thru axles
Shimano 105 Components (all NEW except gently used Stages left crank):
R7020 shift levers
R7020 flat mount brake calipers
R7000 34.9 front derailleur, R7000 SGS mid cage rear derailleur
R7000 172.5 36/52 crankset with Stages Gen3 left side power meter installed (and original, non-power crank arm included)
CS7000 11-32 cassette
HG701 chain
Wheels (NEW):
Shimano RS710 C46 46mm carbon tubeless, 21mm interal width, 28mm external width
Panaracer AGILEST TLR 28mm tubeless tires with Orange Seal Endurance
Shimano RT-CL800 160mm disc rotors
Cockpit (NEW except gently used saddle)
Whisky No. 7 110mm stem (can also include the same stem in 100mm)
Whisky No. 7 12F 42cm handlebar (12 degree flare)
Whisky No. 9 carbon seatpost, 27.2 x 400mm, 18mm setback
Fizik Arione Titanio Seatpost
Wheels Manufacturing matte carbon spacers (1x 10mm, 4x 5mm)
2022 Salsa Journeyer 57cm Custom GRX New Build - $2200 shipped or $2000 local pickup in Boulder
more pictures here: 2022 Salsa Journeyer 57cm Custom GRX New Build - bicycles - by owner... (craigslist.org)
Less than 100 miles on this Salsa Journeyer 57cm frameset purpose-built to tame the roughest gravel.
Salsa Journeyer 57cm alloy frameset features 4 bottle mounts, three pack mounts on the fork, internal brake, shifting and dropper routing, clearance for 27.5 x 2.1 or 700x50c tires.
Shimano GRX810 brakes, lever (right rear shifter, left dropper lever), 1x 42T crankset 172.5mm, rear derailleur, HG701 chain, M7000 11-42 cassette, RS500 BB
Shimano GRX570 650b wheelset, RT70 160mm ice-tech rotors, Panaracer GravelKing 650x53mm (27/5 x 2.1) tires
Pro Discover Big Flare 30 degree handlebar (44cm), Discover stem (90mm), Discover bar tape, Discover Dropper Seatpost, WTB Silverado Saddle
Stages GRX left crank powermeter optionally available for + $200
FULL SPEC:
R7020 shift levers
HG701 chain
Wheels (NEW):
