jimatbeyond wrote:
What is the crank arm length?165mm
@cyclenutnz, what makes you think I need shorter cranks?
cyclenutnz wrote:
Sorry about that. If you need a solution for 5 weeks time, then sure - get a 40mm longer stem, it will feel a lot better. But it will make the bike feel less stable, whether or not that is a problem is individual - some people don't care and others do.
What info were you given from the fit?
Below is a data handout I was given for my fit. The QR PRFour data is in the far right column. My pads are further forward than noted in the handout, as I moved them to try and get more reach.
The other two columns are before and after fits on my Canyon Endurace road bike (incorrectly labeled as Canyon Ultimate). The Endurace (size S) I purchased years ago without being measured by a fitter and it turned out to be too small. I brought it to a fitter (different than the QR) who put on a longer stem. I still suspect the bike is too small (reach). Anyway, I mention it because I suspect the new fitter based my QR measurements/recommendation on my Canyon.
