I’m replacing my old square taper crank with a new one, but a Sora crank with a left arm power meter will be like ~400. I’d be remiss to check if I there wasn’t somebody here that had something similar already.
Classifieds
Re: WTB: Shimano 9sp 165mm Crankset w/ power meter [Driva77]
Driva77 wrote:
I’m replacing my old square taper crank with a new one, but a Sora crank with a left arm power meter will be like ~400. I’d be remiss to check if I there wasn’t somebody here that had something similar already.There is no actual 9-speed Shimano power meter. The closest you'll get is a 10-speed SRM 7800 powermeter. All others require 11-speed chainrings. Someone here is actually selling a 165 mm Shimano SRM.
Also, if you are using an old Sora crank, you'll want to check that it is compatible with Hollowtech crank arms.
Re: WTB: Shimano 9sp 165mm Crankset w/ power meter [echappist]
Would a 9sp chain work on a 10sp crankset?
Yes.
Driva77 wrote:
Would a 9sp chain work on a 10sp crankset?In general, yes
