Specialized 2020 Tarmac Disc Expert, 56 (Satin Black/Chameleon/Gloss Tarmac Black)
This size 56 2020 Tarmac is like new with under 100 miles total on it. All miles were outside on the road. In addition to the factory specs below I added the Specialized Power Crank (172.5--Shimano 105) on the non-drive side.
DropBox Photo Link: https://www.dropbox.com/sh/y44lypcjtmowtye/AABy_IAW9q9WROZRT1ZobsFDa?dl=0
Speedplay pedals not included. $4,800. Buyer pays shipping & PayPal fees if using PayPal.
Specs:
FRAME
Tarmac SL6, FACT 10r carbon, Rider-First Engineeredâ„¢, OSBB, clean routing, internally integrated seat clamp, 12x142mm thru-axle, flat-mount disc
FORK
FACT 10r carbon, 12x100mm thru-axle, flat-mount disc
FRONT WHEEL
Roval C 38 Disc, carbon, tubeless-ready, 38mm depth, 24h
REAR WHEEL
INNER TUBES
Turbo Ultralight, 48mm Presta valve
FRONT TIRE
S-Works Turbo, 120 TPI, folding bead, BlackBelt protection, 700x26mm
REAR TIRE
CRANKSET
Shimano Ultegra R8000, HollowTech 2, 11-speed, 52/36T
BOTTOM BRACKET
Praxis, BB30 for Shimano
SHIFT LEVERS
Shimano Ultegra Di2 Disc R8070
FRONT DERAILLEUR
Shimano Ultegra Di2 R8050, braze-on
REAR DERAILLEUR
Shimano Ultegra Di2 R8050, GS medium cage
CASSETTE
Shimano Ultegra R8000, 11-speed, 11-30t
CHAIN
Shimano Ultegra, 11-speed
FRONT BRAKE
Shimano Ultegra R8070, hydraulic disc
REAR BRAKE
HANDLEBARS
Specialized Expert Shallow Drop, alloy, 125mm drop x 75mm reach
TAPE
Roubaix S-Wrap
STEM
Specialized Pro SL, alloy, 4-bolt
SADDLE
Body Geometry Power Expert, Hollow Titanium rails
SEATPOST
S-Works FACT Carbon Tarmac seatpost, 20mm offset
SEAT BINDER
Tarmac SL6 clamp assembly
https://www.specialized.com/...earchText=90620-3156
Specs:
FRAME
FORK
FRONT WHEEL
REAR WHEEL
INNER TUBES
FRONT TIRE
REAR TIRE
CRANKSET
BOTTOM BRACKET
SHIFT LEVERS
FRONT DERAILLEUR
REAR DERAILLEUR
CASSETTE
CHAIN
FRONT BRAKE
REAR BRAKE
HANDLEBARS
TAPE
Roubaix S-Wrap
STEM
SADDLE
SEATPOST
SEAT BINDER
