Ian
I had a pro bike fit with my current tri bike. Would love to get fit assistance on the new speedmax - CFR and Disc version(s)
Height: 5'4/64in and inseam of 28-29 (closer to 29).
Current tri bike setup - Cannondale slice 51, 155mm cranks.
Seat height - 695mm
Pad Y - Arm Pad Stack BB - 632,,
Pad X - Arm Pad to Grip reach - 343mm; Grip Reach (tip of saddle to front end grip) - 745mm, arm pad reach (tip of saddle to back of arm pad),- 402mm , arm pad to grip reach - 343mm
According to canyon - might be an XS (or it just might be a bike that is not a good fit for me :( )
Andrew,
If you've had a bike fit and you like your position I'm just gonna run with the Pad Y of 632 and Pad X of 402.
For the CFR the size would be a small - which might be a good thing because Canyon doesn't sell and XS in the CRF in the U.S.A. You'd be perfect with the short stem that comes stock. It looks good.
If you went with the SLX version... there is an XS in that bike and that would work as well - and again with the short stem that comes stock. You'd need the large pedestal plus some extra bit in the box of goodies to get the Pad Y where you need it (632) as this bike maxes out at 638ish.
Ian
Ian Murray
http://www.TriathlonTrainingSeries.com I like the pursuit of mastery
Twitter - @TriCoachIan
