Re: Official Canyon Speedmax CF Owners Thread [TX83]
Re: Official Canyon Speedmax CF Owners Thread [JTNY]
Hi,
I just purchased the cf 8.0 di2 model and looking to change cranks to 155mm. Rotor Aldhu were recommended by bike fitter but having some issues trying to determine:
1. Any issues in general with these cranks and this bike/be?
2. Which pieces to buy?
Thanks for any help.
Hey guys!
Got the Speedmax CF with the Canyon V21 90mm stem. Unfortunately they don't have a longer version of it.
Anybody got some experience with a longer stem that doesn't look completely off? Ideally 110 or 120mm.
The Aeria Ultimate has only 100mm and has a hefty weight to it (not a weight weenie but still.. it's hefty)
Re: Official Canyon Speedmax CF Owners Thread [mart1n]
Quick noob question , why would you use 28 instead of 25 ? The rear space seems very small .... your 28 doesnt touch the frame ?
I am surprised !
I am surprised !
Re: Official Canyon Speedmax CF Owners Thread [Winol]
I purchased the Speedmax 8.0 Di2 version with the DT-Swiss wheelset but in one week I have changed 3 tubes. I am now pretty sure it is not a tube problem, but either the rim or the tire. Anyone experienced this before?
Winol wrote:
Quick noob question , why would you use 28 instead of 25 ? The rear space seems very small .... your 28 doesnt touch the frame ? I am surprised !
Why 28mm? Essentially did it for comfort. I am a heavier rider, hence usually would need to amp up the pressure and wanted to counter this. The occasional railroad tracks, cracks in the pavement - everything is a breeze, especially with the combination of tubeless and the width. Most probably not the best for aero, but comfort in the position and being able to hold it matters more in my view.
Pics: https://photos.app.goo.gl/4SAn5gvg3D9Wg2SG9
Sorry for the non-driveside shot :)
Perfect ! Nice looking bike :)
Re: Official Canyon Speedmax CF Owners Thread [skyjuice]
I literally just bought this bike two days ago, should be arriving Thursday. Can't wait to try it out. Why not just set your wheels up tubeless? The DT swiss wheels are supposed to be tubeless ready. Changing 3 tubes in a week though is pretty surprising, maybe pinch flats?
Are you liking the bike? Can't wait to get out on it. Switching over from a 12 year old Orbea, I think it'll be a big difference :)
No rubbing issue at all? What pressure are you running on?
No rubbing seen so far, yes. Last rides have seen some sections with wettish leaves thrown in, which might make it even more tight, but no issues. Running it roughly been 4-5 bar, which should equate to 60-70psi.
skyjuice wrote:
I purchased the Speedmax 8.0 Di2 version with the DT-Swiss wheelset but in one week I have changed 3 tubes. I am now pretty sure it is not a tube problem, but either the rim or the tire. Anyone experienced this before?I thought that wheelset was tubeless?
Re: Official Canyon Speedmax CF Owners Thread [kenlenuiuc]
Odd question...but has anyone changed the Canyon decal logo on the speed max. I am considering buying the all black Speedmax but then getting a custom decal in Red (maybe) but not sure if that would just ruin it...all black is a bit boring for me. Any thoughts?
Re: Is there a Canyon owners thread? [soll]
Is anyone aware if the new bento box on the Speedmax CF Disc is compatible with the previous version of the frame?
Canyon CF8 with Profile Design front hydrations systems : Aeria or FC system ?
Hi,
I just ordered a Canyon CF8 Di2 and would like to install a FC or Aeria system on it without having to change the original Canyon handlebars.
#1 Did anyone successfully install the FC system? (It seems that the gap between aerobar is too narrow to fit the attachment brackets and thus may be a no go )
#2 If I have to go with the Aeria system, do I just need to order their 100mm stem and hydration container? or are other accessories required (e.g. spacers for the stem etc..)?
#3 S bend handle bars to narrow hand position & go around hydration system ?
Does anyone have a good suggestion for S type aerobar compatible with Canyon handle bars and Di2 system ? The S shape should allow to "wrap around the hydration system and help get a parallel grip and closer hand position than the Canyon original L bent bars.
Thanks in advance for any answer and suggestion.
Cordially,
FG
Cordially,
FG
Re: Canyon CF8 with Profile Design front hydrations systems : Aeria or FC system ? [FG@cekoia]
The only thing you need to do with the aeria hydration is that you'll hav to shave down some plastic on the stem spacer.
As far as width of bars go it will fit. And since these are 'clip on' bars its wasy to widen them anyway
Tower 26 Swimmer
IG - @ryanppax
Tower 26 Swimmer
IG - @ryanppax
Re: Canyon CF8 with Profile Design front hydrations systems : Aeria or FC system ? [Ryanppax]
Hi,
Does anyone know if the Bontrager RT rear light fits well the seat post of the Speedmax? I mean, without any additional adapter.
Anyway, I would really appreciate any recommendation for rear lights for a buyer based in Europe (any wiggle link?). I've tried some cheaper options and ended up breaking the mounting straps. A light you can't mount and leave at home is a waste of money
Re: Is there a Canyon owners thread? [filipinos]
filipinos wrote:
Is anyone aware if the new bento box on the Speedmax CF Disc is compatible with the previous version of the frame?I don't know, but I'm also guessing if the new toolbox near the crank is also compatible. Is anyone aware?
cmart wrote:
Hey guys! Got the Speedmax CF with the Canyon V21 90mm stem. Unfortunately they don't have a longer version of it.
Interested in the same info. Were you able to figure any options out for this?
