Di2 Front Sticking Mid Shift
Any thoughts on troubleshooting front Di2 sticking mid shift from large to small chainring.
I am new to it and wondering if tapping the button or holding the button on front control makes a difference.
It shifted well upon arrival and charging, smooth shifting front and rear. Noticed this issue suddenly last ride. Battery shows green, though charged month ago. Not charged since. Thanks.
Re: Di2 Front Sticking Mid Shift [atasic] [ In reply to ]
Tapping or pushing the button fully shouldn't make a difference as far as I know.
If this is a new bike I would definitely ask the LBS to take a look, this shouldn't happen.
The remaining battery charge doesn't matter in this case - either the FD shifts or it doesn't. Once the battery charge reaches 10% or so (not sure about the percentage) the FD will stop shifting completely until you charge the battery.
BetterShifting.com - Di2 help and guides| BetterShifting Instagram | Terry's Instagram
Re: Di2 Front Sticking Mid Shift [Di2Terry] [ In reply to ]
Thank you.
Which model FD? The newer models don't have an inner limit screw; they use a soft inner limit that you program manually. It's possible you went into this mode and messed it up. Read the installation manual (online).
