Hey all,
anyone out there also owning a 2020 Scott Addict with Sram Force AXS.....I think it is an awesome bike and I really like it. One thing that drives me nuts however is that both brake pads front and rear are not aligning properly with the end of the rotor. Each pad is basically overhanging by about 1.5 mm. Obviously, these 1.5 mm of pad remain and are not rubbed off while braking....
Have others also observed the same? Will that be a problem down the road? Are there 160mm rotors that come in a little bigger which would make the pad to be cover by the rotor?
Thanks a lot.
Uli
Thanks a lot.
Uli
