Rideon77 wrote:
wintershade wrote:
Has anyone else on this forum had recurring bouts of hemorrhoids, itchy anus, anal fissures, presumably as a result if cycling? It’s kind of scary seeing streaks of bright red blood in your bowel movements, or so I’m told. What did you do to “fix” it? Taking a month off of cycling is not an option. Because mental health > anal health.
Asking for a friend.
Your talking about two different things. Hemorrhoid's can be internal or external and both are treated differently. A fissure (a fistula) is a hole or tube between two different places that shouldn't exist.....its an abnormal connection. Sometimes they resolve on their own others need surgery. An itchy anus can be a few different things but in this case sounds hemorrhoid related.....just so your "friend" knows.
A fissure and a fistula are actually two different things, especially in that area. A anal fissure is essentially a tear in the lining of the anus, whereas a fistula is an abnormal connection between two sites as such. It would be very unlikely at this point in time that the OP has a fistula.
So a few things to note: surgery for haemorrhoids is bloody rough. There are some newer therapies which apparently are no where near as bad but by in large surgical options are not pleasant and you will be out of action (and in pain) for quite some time. Hence do all you can to try and manage them conservatively. If you are getting fresh blood in your stool from them or the fissure it would suggest you really need to be on some stool softeners so you are not straining and pushing out massive poops! Have you or your friend tried any haemorrhoid creams yet? They are generally reasonably effective depending on what you have down there....
In terms of not cycling....your primary care doctor will probably say to avoid the bike but in reality if you are careful with what you do you can probably see how things go and as long as the overall trajectory is that they are getting better then I would carry on. Good luck.
