Powertap G3 Hub - 11 speed compatible?
Just want to make sure that all Powertap G3 hubs are 11 speed compatible.
I had another wheel that already had an 11 speed freehub but I think it had orange letters. This one is yellow.
https://photos.app.goo.gl/eqGtsdPfEtDeMNMe9
Any help is appreciated!
Re: Powertap G3 Hub - 11 speed compatible? [Chan] [ In reply to ]
If it has a 15mm axle it'll be compatible. If it's 12mm it's not.
Re: Powertap G3 Hub - 11 speed compatible? [Benv] [ In reply to ]
Easy peasy. Will check tomorrow morning
It should be compatible - worst case scenario with a different freehub. i recently looked to upgrade my old Powertap Pro+ but it has a 12mm axle and therefore did not work.
Sorry that's what i meant. Didn't want to order a new freehub to have to return it later
Yes it will be compatible. All the G3s are based on the 15 mm axle. The Shimano freehub has a spacer to convert between 10 and 11 speed. There is maybe a chance that it would have an older freehub body if someone swapped it out, but I am almost completely sure that these are Novatec freehubs. Much cheaper to pick those up off of Ebay.
I have an 11-speed cassette on my Powertap G3 hub. Which is for sale btw. ; )
Re: Powertap G3 Hub - 11 speed compatible? [phoenixR34] [ In reply to ]
gearing? I'll see about checking it out
