Charging Di2 how to remove end cap
I need to charge my Di2 on a Tarmac and the battery is inside the right handlebar. How do you remove the end cap to access the battery?
I checked the owners manual and also YouTube and could not find anything.
Re: Charging Di2 how to remove end cap [Pieman] [ In reply to ]
You charge Di2 through a plug in the Junction A component. The Junction A is either a little rectangular thing by the stem with several wires going into it. Or it is an end cap on your handlebars with an LED and a small button. If the latter, the port is under a little plastic cap under the button.
Re: Charging Di2 how to remove end cap [exxxviii] [ In reply to ]
Found it, thank you. It’s very small and hard to see.
Makes it easy to charge though.
... and if you have a Windows PC you can also use that port to connect the bike to a computer and change settings ;-)
BetterShifting.com - Di2 help and guides| BetterShifting Instagram | Terry's Instagram
Re: Charging Di2 how to remove end cap [Di2Terry] [ In reply to ]
One more question. How do I know it is fully charged? Do I hold down the button until the lights flash and then make sure it shows green?
Hold down any shifter button for ~0.5 sec. Some people hold both shifter buttons (on road levers).
Also - the charging LED (on the charger itself) will switch off ;)
You may also find this useful (disclaimer: my page)
https://bettershifting.com/...oichargemybikeandhow
That is really helpful information in the attachment. Thanks.
It should have come with the owner's manual. That would have made things much easier.
