Re: Platypus Thread: Aero Virtual Elevation Testing Protocol [BergHugi] [ In reply to ]
BergHugi wrote:
Looking at tests of the recumbent community, they often observe an increase of Crr with speed
Yeah. I've seen those claims, too. I'm sure that at very high speeds it does matter. The question is whether on a velodrome at more usual speeds whether the speed dependence is large or small.
I have a couple of data files from streamliner speed runs at Battle Mountain. There are a couple of anomalies but, as a whole, it appears that the speed dependence of CdA and Crr isn't huge in speeds from ~40 to ~75 mph (~65 to ~120 km/h).
Re: Platypus Thread: Aero Virtual Elevation Testing Protocol [RChung] [ In reply to ]
I´m going to test with top cyclists between 45-50km/h.
Copy text from this article "Simulation Model for Road Cycling Time Trials with a Non-constant Drag Area
: "The Martin model can be modified to account for variation in CDA with variations in the Reynolds number of the air flow. To do this, the model must use the effective wind velocity parallel to the riding direction given a certain yaw angle, to return the correct drag area for those conditions. For this model, these values were obtained through wind tunnel testing"
I understand for this that Cda calculated is only valid for the same velocity. I can read in other papers that is one of the limitation of wind tunel test. Cda is high at low velocity and low at high velocity. Then we need to report cda value allways at specific velocity.
About Crr is also dependent of velocity I should test Crr at target velocity.
Anyone can explain or link how do accuracy test of Crr in velodrome?
Re: Platypus Thread: Aero Virtual Elevation Testing Protocol [cyclistgo] [ In reply to ]
"Simulation Model for Road Cycling Time Trials with a Non-constant Drag Area"
Thanks. That's an interesting paper. I see they did their field tests with speed (and gradient) measured by GPS (and the power meter was a Stages).
They report a dependence of CdA on wind tunnel speed that's huge: there's about a 5% difference (for both riders) in CdA between 9 and 13 m/s (about 32 to 47 km/h). That's puzzling.
I can understand now why you're worried.
BergHugi wrote:
Did not do many tests with my test rig yet, but I saw a slight increase of Crr for a Schwalbe pro one TT from 0.0016 to 0.0018 increasing speed of the wooden drum (d = 90cm) from 20 km/h to 60 km/h .Loooking at tests of the recumbent community, they often observe an increase of Crr with speed
Cool... is your test rig posted somewhere?
Very low Crr... I've been getting ~.0025 with Vittoria Pistas at slow speed. That's on a road though.
Re: Platypus Thread: Aero Virtual Elevation Testing Protocol [rruff] [ In reply to ]
Not yet. I will write a paper when every thing is fine i.e. when the results are bullet proof and when I have the time to write. In the mean time look at the picture.
Yes, I measure generally low Crr values. But tests are on a smooth wooden drum (I want to be as close as possible to a wooden track surface), results are corrected for drag to spin the drum and the wheel, and results are recalculated / corrected for a flat surface.
I understand RChung, that the best option is not try to calculate Crr on velodrome, is get data from roller test, or from data tables from https://www.bicyclerollingresistance.com/road-bike-reviews?
If I decide to get data from other experiments, how should I convert or adjust this factor of Crr to my test? For temperature?
I´ve been reading about aerodynamic very different things...
RChung wrote:
cyclistgo wrote:
Cda is dependent for velocity only for Reynolds number?
Um, maybe I made things more complicated than I should have. The essential piece is: over the speeds at which we usually ride, CdA is not dependent on speed. If it were, we wouldn't be able to predict pwer for speed based on wind tunnel tests that are done at a single speed.
I would add that in terms of pressure drag yes (eg. components, bike frames, wheels), but friction drag the CdA will change (skinsuits etc.) even over 35-50kph.
Regarding Crr round a velodrome you can do it with the TAS kit but as mentioned above it's really hard and you have to devote entire sessions to doing just that. We did some for a recent bit of data correlating things with wind tunnel and Crr data (see herehttps://www.aero-coach.co.uk/...mics-of-racing-tyres[/url] ).
Low 0.002s for Anadia is the correct value. Local temperature can vary quite a bit - gets really really hot there in the summer.
AeroCoach UK
http://www.aero-coach.co.uk
Re: Platypus Thread: Aero Virtual Elevation Testing Protocol [Xavier] [ In reply to ]
Thanks for your answer Xavier. ¿What are you mean with TAS kit? ¿Aerodynamic system TAS? I understand that TAS is also regression on real time.
We are going to stay also in Valencia in August-September and I´m thinking in get data from test roller, one for concrete and another for wooden, and control stable all variables along test for get the most accuracy Cda in velodrome and Crr in test roller. Same pressure, same tyres and same velocity, and adjust for temperature and weight.¿Could be this a good idea? ¿Which limiting factors could have this methodology?
No, I'm not sure that's the *best* option. Crr differs across velodromes, so whether that's the best option depends on if you can get away with transferring Crr values from another testing situation, and that depends on how precise you need to be.
The purpose of models isn't to fit data, but the test of a model is. If you think that Crr (and CdA) vary with speed, the thing to do is to test it. Our current model of drag forces (slightly simplified to get rid of the potential and kinetic energy terms and assuming no wind) looks like
Watts = Crr * m* g * v + 0.5 * rho* CdA * v^3
or
Force = Crr * m * g + 0.5 * rho * CdA * v^2
So the test to determine dependence of Crr on speed is to estimate the coefficients of a model that looks like
Force = A + B*m*g*v + C* v^2
and see whether the coefficient B is different from zero. The problem is that you also think that C is speed dependent, so interpreting B may be hard -- but at least you'd know if dependence was an issue. You might also be able to vary m to separately estimate a Crr dependence and a CdA dependence, but I have to think on that a bit more.
Thanks RChung. I need to think in your answer, interesting.
Which variables change on Crr measure in roller for the same material of the track to be different?
If from my point of view regression method is not valid for consider that we have one Cda for one specific velocity, also for Crr, which could be other alternative method for measure Cda and Crr with high accuracy?
or
what would it be in this case A, B and C?
I can find here https://www.tiresciencetechnology.org/....2346/tire.20.190207 that Crr have non-linear relation for velocity above 45 km/h.
Well, I was simplifying. In the usual Martin model, A is an estimate of the quantity Crr*m*g and C is an estimate of the quantity 0.5*rho*CdA. In this case, you'd be testing to see whether B is non-zero. If it is, you'd have to do another test to determine whether it's non-zero because of speed dependence of Crr, of CdA, or of both. I was thinking that would require some variation in m, since rolling drag is affected by mass but CdA isn't.
And, of course, VE is actually designed as a diagnostic for these kinds of things -- and it's pretty sensitive.
That's interesting. I'd like to see how they tested. As I mentioned above, I have some data on actual speed runs at Battle Mountain and if the dependence of Crr on speed were large I think it would've shown up. (I was actually kind of surprised when I first saw the data because I was expecting to see a "regime" change in Crr and CdA but I didn't).
We really need a "Paper Police".
Not saying their paper is invalid but I would love for someone to check it out
I recently had to take a paper, take the raw data and dissect how they came to such flagrantly wrong results. Which they published. All user error.
There has to be a better way to review/comment get some of this stuff retracted
Again, I am not targeting this specific paper or saying it is wrong, I just now question every paper that I read.
Re: Platypus Thread: Aero Virtual Elevation Testing Protocol [marcag] [ In reply to ]
I thought the paper several posts above that did field tests with GPS speed and gradient and a Stages power meter was kinda fun.
RChung wrote:
...GPS speed and gradient and a Stages power meter...
I noticed you noted that. :-)
Damon Rinard
Engineering Manager,
CSG Road Engineering Department
Cannondale & GT Bicycles
(ex-Cervelo, ex-Trek, ex-Velomax, ex-Kestrel)
TAS is the real-time Track Aero System developed by AndyF for Alphamantis/Garmin.
Re: Platypus Thread: Aero Virtual Elevation Testing Protocol [damon_rinard] [ In reply to ]
Do you know me, or what?
Nice! I don't know what instrumentation you are using, but I wondered if it would be best to determine the inertia of the system and derive Crr from the rate of change in speed. Would be better than some hacks at least (like measuring motor inputs) and would be simple and consistent.
It could be simple and consistent--unless you think Crr varies with speed.
Actio = reactio, with a wheel hub motor no need to measure motor inputs, just get the reaction torque with a lever and a load cell (grade A)
rruff wrote:
marcag wrote:
rruff wrote:
Based on outdoor testing I'm pretty sure Crr increases with speed, making the relationship with power non-linear. At least that is the only way I could get curves to match.
If this were true, how would you explain not seeing it on indoor roller tests ?
I do though not as much as for the outdoor tests, where there is an increase of ~50% between 10km/hr and 40km/hr.
Does it mean you saw a 50% increase of Crr between 10 and 40 km/h according to your outdoor tests ?
Thanks
Large variation of Crr is true for car tires:
https://www.researchgate.net/...vehicle/figures?lo=1
In velodrome, instead of varying speed to differentiate Crr and CdA, is varying mass at targeted speed could be a solution ;-) ?
Blog | Twitter| Bike CdaCrr app
Re: Platypus Thread: Aero Virtual Elevation Testing Protocol [bugno] [ In reply to ]
That's a very good idea. Maybe you could do runs with empty and loaded water bottles. Maybe fill one water bottle with something heavier than water, to get a larger delta in mass. Hmmm.
In the turns one already get‘s a significant normal force increase depending on the speed and the curve radius. However this effect was not big enough in my tests to separate Crr from CdA.
By the way, what publication could I cite if I want to make a reference to the „Chung“ or „virtual elevation“ method in a scientific paper?
RChung wrote:
cyclistgo wrote:
My question is about if it´s possible to determine in stable test Cda and Crr or is necessary change velocity.
And with it we can get lot of combination numbers for Crr and Cda.
Estimating CdA and Crr from the same data set is possible but it's pretty demanding of good data and good experimental technique. The short answer is it's necessary to change velocity. The fuller answer will require a little dip into statistical estimation. I'll try to keep it short and understandable.
In order to estimate two unknowns, you need to have at least two equations. If all your data are taken at a "stable test" at a single speed or power, you'll only have one equation so the system is undetermined. What's also true is that if the data vary but only by a little bit, you you can solve for estimates of CdA and Crr but the data are *nearly* collinear so although you were able to do the estimation, they're estimated poorly.
So, if you're trying to estimate both CdA and Crr from the same data set, you have to have a pretty wide range of speed and power--and it's good to have a lot of equations so you can check the precision of the estimates (there's a bunch of statistical mumbo-jumbo embedded in the last part of that sentence). A secondary issue is that you'd like the speed and power to be pretty accurate and precise, and a third issue is that you don't want there to be wild swings in speed and power because some power meters are a little sensitive and laggy in responding to big changes in power.
All together, if you want to separate CdA and Crr, you need accurate data and a wide range in speed and power.
Andy Shen once suggested a monotonically increasing speed protocol for velodrome testing: start slow and increase speed a little bit each lap. There are other ways to ensure that you get a pretty wide range in speed and power, but this will work. Find the top power you can sustain for a couple of laps, then start at perhaps half of that power, then each lap increase speed smoothly so that after 10 laps or so you're at your max that you can sustain without ruining your position. If you can, do a couple of extra laps slowing down in speed and power. A protocol like this ensures both a wide range in speed and power, and also keeps sudden changes in them relatively small.
Andy Shen's description is still out there on the interwebs: https://nyvelocity.com/...ess/the-shen-method/
rruff wrote:
BergHugi wrote:
It is often stated, that because power to overcome aero drag scales with the cube of speed and power to overcome rolling resistance scales linearly with speed it is possible to separate Cda and Crr. I was never successful to separate them with actual power data from an aero test on an indoor track.
There is also a more modest *reduction* of CdA with speed for most people.
Is it possible you could have been bumping up against "impedance breakpoint" in those tests? The breakpoint is not only affected by pressure, but also speed, load, and surface roughness.
I only ask, because if there was a dramatic increase in Crr with speed, then I highly doubt I would've seen such "clean" plots when I was playing around with a "work per lap" spreadsheet Adam Haile had sent me quite a long time ago. As an example, here's one of the plots below:
Speed varied within the laps from 7kph to 55kph, with the overlapping lap segments averaging from 25-41 kph.
