Hi everyone! Am working on specifications for a new TT/tri bike and have concluded that I want to go with disc brakes and ENVE SES 7.8 wheels.
ENVE wheels come with centerlock hubs which is fine if I want a centerlock rotor, but the industry standard is 6 bolt and would therefore require an adapter and bolts. It seems to me from an engineering and design perspective that centerlock is a better choice. If this is the case, then why has 6 bolt become the industry standard? I believe that 6 bolt rotors are lighter (for example Ti-Carbon), but by the time you add the adapter and bolts, most of the weight savings would be negated.
Is there a compelling reason to be considering 6 bolt rotors or is the SRAM Centerline XR rotor (Centerlock) the way to go?
Thanks in advance for your input.
Jason
Jason
