Crash_Davis wrote:
The big selling point for me will be puncture resistance. Are the Schwalbe Pro 1’s as puncture resistant as the Conti GP4000’s? When they do puncture, will the sealant seal the puncture w/o significant loss of psi? Only time will tell, but for now I am glad I gave road tubeless a try.
Glad to help, and good to know that my articles and videos aren't going out into the ether with nobody seeing them!
As for puncture resistance, it's hard to say. I've ridden Conti GP 4000's quite a lot, and I'm currently riding Schwalbe Pro Ones on three different bikes (though one is a test bike that will be back in a box and shipped away soon). I honestly can't remember the last time I flatted on any bike... I live in Florida too, and the roads here are crazy good compared to every other state I've lived in. Historically, I've had most of my road bike flats on handmade cotton tires. So personally, I can't really give you a verdict. I believe the Conti tread is a bit thicker, which suggests a bit better puncture protection - but I have no data to back it up.
Pressure loss - all depends on the size/type of puncture. Larger tires and lower pressure help the chance of sealing (i.e. a 28mm tire will have an easier time than a 23mm tire). I've had a 23mm tire "seal", but when you pump it back up to operating pressure, it started leaking again (the sealant couldn't hold at the high pressure). Your best bet is to make sure you have enough sealant in the tire - it will dry out over time and you need to add more. And shake the sealant well to be sure you're mixing up the particles evenly.
Maybe I should do a puncture test before I send my test bike back? ;) I swear, I was just ridin' along, and the tire magically got a big hole in it...
