cmscat50 wrote:
Any idea what tire width and pressure Sebi is running? Or what they are running in the pro peloton for pressures?Re: Sebi - I don't have that info. With the pro peloton, 25mm tires are basically the new minimum size for both road and TT... with probably an exception or two. More 28's are showing up. I don't have a lot of pressure info because they tend to be fairly secretive, so I asked my buddy Dan Cavallari over at Velonews who spends a lot of time covering EU races. He said that they still tend to err on the high side (which sounds to me like a carryover from the old days of running realllllly high pressure on narrow tires). Anyhow, Dan said that he doesn't think that anyone is running over 85-90psi on 28's, which sounds high to me. I normally run about 72psi front, 75 rear on 28's and I'm a fatty @ about 200 lbs (been lifting weights and stuff). I never pinch flat. Dan weighs about 10 lbs less than me and said he runs 75-80 because he prefers a bit firmer feel. I run about 80-85 on 25s... and I never ride 23's anymore.
