Re: Let's See Your Slice! [Tsunami] [ In reply to ]
Quote:
Tsunami Oct 15, 18 17:27
Question for you. I see the Tri Rig Omega front brake. Did you happen to change the rear brake too? If so, any issues fitting another Omega there?
Yes, Omega on the rear. I had to use one of the included brackets, which cause it to stick out a bit. I was assured by Tririg that I mounted correctly. It offended me for a minute and I got over it. Way better braking with the omega.
I am sure to clean out the fairing and in particular the magnets. I have been riding it for ~3 years now and haven’t lost the cover.
Re: Let's See Your Slice! [Duffy] [ In reply to ]
Updated my ~2010 Cannondale Slice after really loving the Etap conversion I did on my roadie recently.
Sram Etap 11speed
Compact 50/34 165mn crank
Garmin Vector 3 Pedals
TriRig Brakes front & rear (I did the same on my aero roadie and I love their stopping power)
TriRig alpha bars and Gamma extensions. (love the new front end!)
Torhans bento box (the frame owes me nothing, so boldly went where tri rig did and installed bottle bosses in the top tube)
Flo 45 Carbon Clinchers (replaced my old Zipp 404 10sp w/ Power tap)
Etap Clicks on the end of the extensions, and blips mounted underneath the pursuit bar for shifting from either position.
Feels like a brand new bike now and looks sweet! Super pleased with it. Makes me excited to ride again. I don't miss the R2C shifters at all. She shifts like a dream now.
Re: Let's See Your Slice! [Nickwisdom] [ In reply to ]
Very nice and clean. I don't see any zip ties; are you sticking your bento on there?
Edit: never mind, I finally read that you added bosses...would love to see pix of that. I briefly thought about that, but the tube is so narrow and I am chicken.
Re: Let's See Your Slice! [ale_ers] [ In reply to ]
Not for the faint of heart.... I drilled holes in the top tube and riveted in bottle bosses for the bento. Tutorial on where I got the idea below. It will void your frame's warranty.
https://www.tririg.com/...rage_Bosses_Tutorial
He mentioned he followed this TriRig guide to install your own bento bosses on any bike with a flat top tube. I wanted to do that on my p3c but it had too much curvature and I wasn't sure how it was going to work out. Does look really good though.
Benjamin Deal - Professional - Instagram - TriRig - Without Limits
Deals on Wheels - Race reports, pictures, sponsors, and more!
Most recent video: $20 photochromic cycling sunglasses review
Most recent blog post: A Nod to Women in Sports
Re: Let's See Your Slice! [realbdeal] [ In reply to ]
It will work just fine on a P3C as long as you are careful. The most important part is to ensure each hole is centered on the top tube, so that each rivnut will be centered and axially aligned.
TriRig.com
My 2015 green / black / white Slice got a total make over: paint, electronic shifting, and bar / brake upgrades. I've been taking pictures in different locations, at different times of day, from different angles, but I haven't hit gold yet. Decided to load something anyway before there is no shot left to take that doesn't involve paint gouged down to the primer.
I'd like to cut the monopost down a bit at some point, once I'm convinced I'm done tinkering with the build.
Other than some extra flexing to the front end that I wasn't used to, it rides the same as before. I have rolled some familiar courses in slightly faster times on lower wattage but am unsure whether any of that might have to do with the crank / chainring reinstall (? - ETA in the event the power meter needed recalibration or something...).
To breathe, to feel, to know I'm alive.
That's a nice looking Slice
Re: Let's See Your Slice! [BigBoyND] [ In reply to ]
Thanks!
Sram Etap 11speed
I can't tell how you routed the rear brake cable? It normally runs under the basebar and to the left side of the headtube into the frame and comes out on the left side of the rear top tube. Did you route it differently? I also have a 2010 Slice that was recently upgraded to Etap.
Re: Let's See Your Slice! [Billyk24] [ In reply to ]
The brake cable exits from the center of the basebar and then goes into the top tube entry port through the bento box. I had to carve out a portion of the bento box bottom to make this possible. The brake cable housing then gives me something firm to route the etap wires along to the blip box that also lives in the bento box. Hopefully that made sense. I'm away from the bike or I'd add photos.
You TriRiged punched three holes into the top tube (one for brake cable, two for the bento bag) to make this setup work? I agree the Etap setup helps minimize cable cluster.
Nope.... I installed two top tube bosses for the bento, but there was already a cable entry port towards the left hand side of the top tube on my slice.
Looks sick!
Re: Let's See Your Slice! [Timk] [ In reply to ]
My 2012 Slice in Roth 2019.
My race site: https://www.racesandplaces.net/
Re: Let's See Your Slice! [Jigsy] [ In reply to ]
Here’s mine. I just purchased a vision base bar because I don’t like how the handles flip up.
Thought I could ask this here instead of making a new thread for it..
Does anyone with a Superslice know if you need to fit the standard basebar/stem or had anyone tried fitting a TriRig Alpha One or X for instance with success? Seems like there might be some interference with the head tube/top tube area, the part behind the steerer tube
Re: Let's See Your Slice! [Tri_Joeri] [ In reply to ]
Alpha One doesn’t fit on the Superslice, for exactly the reason you describe. Alpha X does fit.
Both bars work on the standard Slice.
TriRig.com
Re: Let's See Your Slice! [TriRig] [ In reply to ]
Thanks for the quick reply! But the Alpha X is out of stock I see, will they come back in stock or are you all-in on the Alpha One?
I was considering getting a used superslice a few months ago so researched the same options as you (didn't get it in the end for various reasons). Look at Joes cycling reviews on youtube, he dremels the bit behind the stem to fit a standard stem and bars. However he has to remove the headset top cap to get enough purchase on the steerer, although this wouldn't be an issue with the alpha 1. You could do a much neater job with the alpha one.
You could also try and contact EF Pro to see what they do/have any spares they might be able to sell you, as they appear to use current vision TFE integrated bars and stem (not the stock ones that came on the superslice), which are similar in style to the alpha one stem.
Alpha X is long since discontinued.
TriRig.com
