cyclenutnz wrote:
The site is pretty poor for fit info, slowly improving that. You'll learn more from the fit guide I wrote for Wilier although it's not that helpful for other bikes. If you read the instructions in that document you will be able to use the tables below. With the exception that the AU tables are based on cockpit XY - the metrics from frame XY to pad XY (rear, incl cushion). So if you have a target Pad XY and and known Frame XY you can work out the Cockpit XY. Static XY charts are pretty limiting for dealing with tilt. Tririg calculator is really good but the Y gets thrown out as soon as you tilt.
Thanks for all the info!
Comparing with the values I got from my Retul fit, I'm within 1mm of the chart you gave, that is really helpful & accurate (I assume my tilt is in between)
cyclenutnz wrote:
The tilt wouldn't work at all unless you modified the spacers. Which is, of course, not recommended and would void the warrantySo would you say it's safe inverting the brackets without any modifications? I mean I know I will be limited with the tilt, but if I can get pretty close to what I'm currently running that would be awesome!
