Can I Interest Anyone Here in Crushingly High CRR? (Possibly for Some Added Flat Protection?)
https://tannus.co.uk/armour/
In all seriousness though, for some high CRR might be a feature for how they train.
Re: Can I Interest Anyone Here in Crushingly High CRR? (Possibly for Some Added Flat Protection?) [GreenPlease] [ In reply to ]
That webpage suggests it adds comfort. I'm pretty darn sure that's nonsense. Only if their guard goes in parallel with a larger tyre.
Re: Can I Interest Anyone Here in Crushingly High CRR? (Possibly for Some Added Flat Protection?) [Ai_1] [ In reply to ]
Any insert that I have seen in MTB tyres has certainly added comfort.
The foam damps and quietens the bumps significantly.
The bike is eerily smoother at speed through rough stuff.
Re: Can I Interest Anyone Here in Crushingly High CRR? (Possibly for Some Added Flat Protection?) [lyrrad] [ In reply to ]
Ah, for MTB that may be true. I was thinking of road tyres where damping is not really the main problem IMO, but rather lack of tyre distortion. Therefore an insert which reduced the air volume in favour of a less compressible medium would, I suspect, reduce comfort.
Could see this for downhill mtb. You take a ride or chair lift up anyway, so it wouldn't matter. That's also one of the prime pics in the linked site is downhill mtb.
Then again, who would buy this other than tubeless?
Go tubeless and if you hit something THAT bad, mtb and larger tires are much easier to deal with in the wild than tight road race tires.
Rip open a tubeless in the woods, just add a dollar bill or wall patch and insert tube.......ride out.
Just out of curiosity has anyone actually measured the Crr of these? Not that I have any intention of subjecting myself to them, but I am curious just HOW high the Crr really is especially compared to something like a Gatorskin
In addition to high CRR,
How hard would these be to mount on a road bike rim?
Indoor Triathlete - I thought I was right, until I realized I was wrong.
Re: Can I Interest Anyone Here in Crushingly High CRR? (Possibly for Some Added Flat Protection?) [IT] [ In reply to ]
I’ve mounted Cush Core on an mtb rim and it was a major PITA. I’d imagine the spectrum would be “a bit more difficult than a normal tube/tire install” to “major PITA”
Lack of distortion is just too high pressure and these would allow lower pressure by reducing pinch flats.
Inserts do nothing for sidewall cuts, so don't think you can magically run supple sidewalls in trash conditions.
So I don't see any gain for a road bike.
GP4000's go without damage apart from the rock cut to the sidewall that would kill any tyre, so what is there to be gained?
lyrrad wrote:
Not when set up tubeless, but these have a tube inside the insert. There's a dramatic increase in sidewall cut survivability with these. Whether the other compromises are worth that or not are up to the individual rider to determine.
Re: Can I Interest Anyone Here in Crushingly High CRR? (Possibly for Some Added Flat Protection?) [gary p] [ In reply to ]
People, these are for MTB only. Tannus sells solid tires for road bikes with much less CRR. Me and my wife have them on our road bikes. At 6000 miles, getting screws, thorns, glass, nails in them still riding. Would have had to do 15 flat changes by now (no exaggeration)
http://www.coupleofathletes.com
Re: Can I Interest Anyone Here in Crushingly High CRR? (Possibly for Some Added Flat Protection?) [synthetic] [ In reply to ]
They do offer these for road bike size tires (700x28-34)
Do you have actual .crr data for either?
2 years ago I tested a set of of their 700x23 tires. On the slight uphill grade on the road out in front of our warehouse, a set of 700x23 GP4Ks at 95psi required 215w to go 30kph, the Tannus required 288w (and rode like 700x20s inflated to 150psi)...
"I'm thinking of a number between 1 and 10, and I don't know why!"
Tannus stated up to 2% difference on their road tire compared to regular air. The insert must be new for road bikes then. But why? The solid is better solution. 700x25 slicks to me the best as I tested 23-28
Page 18.. not a 60w difference like other guy said
http://www.triclubsandiego.org/...inews-november-2018/
30 minute to change a tire? What the hell is that guy on?
And what the hell are we supposed to do with that info? Nothing is controlled here. This test has no validity.
Comparing to Ritchey Tom Slicks with thorn proof tubes? Those tubes alone evened things out quite a bit, the tires I have no idea about. What would be the result of comparing to GP4Ks with ultra-light tubes, like I did? Even so, there was one lap with each setup that he did in 14:03, the Tannus tires required 19w more. So we're at about a 10% difference, not the claimed 2%. My comment after our testing was their comparison must have been against Specialized Armadillos.
TCSD newsletter wrote:
As one can see from the performance comparison results the Tannus tires did not hold Dean back at all; he was even faster compared to his trusted tire/tube combination
But how fast would he have been if he had held the same average power with the Ritcheys?
Re: Can I Interest Anyone Here in Crushingly High CRR? (Possibly for Some Added Flat Protection?) [Warbird] [ In reply to ]
Right. He was faster because he rode harder. This shows nothing about the tires. We need a test done at the exact same power, in the same weather conditions. And then we need a test done with a "control" tire that most of us use like a GP4k, again at the same power and weather conditions.
Editing to add: we also have no idea what pressure he inflated the pneumatic tire to, which can affect speed a ton
Can you elaborate with more detail on the pros and cons you find with the Tannus wheels?
I am on the verge of pulling the trigger on their preinstalled wheelset for like $280ish - I'm in need of a new wheelset for training and I train almost entirely on my own when I'm outdoors so I don't need every last iota of speed to hang with a fast group - I suspect I can tolerate a little more rolling resistance, as I HATE flats. (I am very capable at changing a flat, but I still hate them, as most do.)
I guess specifically -
- Would you recommend them to everyone for training?
- Any annoyances? (Speed, ride quality being the main ones)
- Worried about the inability to remove them?
Thx
Seems like a product that would have suited the market 10 or 20 years ago.
Pretty much everyone rides downhill and Enduro wirh tubeless these days in DH and Enduro.
Most do on regular trail riding too.
Rim strips can be worth it in the bed of the rim to protect the rim for aggressive riders, esp. In expense carbon rims.
But for puncture protection? 10 years too late.
Not a bad idea. I just did a holiday road ride on my gravel bike which has exceedingly high Crr tires mounted, and it was just about right. I got a good workout without being That Guy who attacks the holiday ride.
Re: Can I Interest Anyone Here in Crushingly High CRR? (Possibly for Some Added Flat Protection?) [trail] [ In reply to ]
I live in suburban Orlando and we have miles and miles and miles of sidewalks nobody ever uses. However you couldn’t safely get a workout on them on a road bike. I bought a Marin steel rigid mtb with burly 27.5x3.0 tires. I put the heaviest butyl tubes in that I could find and I run low-ish pressure. Put my P1 pedals on once and found that a steady 250 watts yielded me about 14mph on a level stretch which is very safe/manageable. It’s unconventional for sure but there is absolutely no way in hell I would ride on the road where I live. I use said bike to go to the pool in the morning (about 20 minutes riding each way vs 15 minutes driving each way), go to the grocery store or the odd local errand, and if the weather is nice on the weekend but I’m pressed for time I’ll ride a loop that’s about 16 miles. It’s not perfect but sometimes you have to improvise.
(I know bikes+sidewalk=nono but seriously... nobody ever uses these. Ever.)
I installed the Tannus airless tires (slick 110psi 700x23) on a set of wheels and can’t recommend them enough. I got the idea after trying out the Specialized Alibi with airless tires (as a gift for older family members) and being impressed.
If I’m riding alone I can’t tell that they aren’t traditional tires, unless there are harsh road imperfections that are taller than about 1 inch.
Not having to worry about flats on commutes is nice, and I can’t be certain but I feel as though the solidity helps against wheel damage that would happen if one were to pinch flat or hit a particularly bad pothole with a traditional tire.
They are definitely about 2mph slower for the same effort around 20mph for me, relative to GP2K with latex tubes, but I only throw on a faster set if I know I am going on a fast group ride and can’t handle the handicap.
I really recommend these tires if you have a spare set of wheels to leave them on permanently.
