Gen 1 Trek SC Max Rim Width
Hi,
This has probably been discussed before but I have a 2013 Speed Concept 7.8. Does anyone know the max rim width that will work with this frame? Is a wheel that is 28mm wide at the brake track and 30mm wide at its widest too wide?
Thanks!
Re: Gen 1 Trek SC Max Rim Width [Bandade] [ In reply to ]
Can't say for sure, but that's probably fine, so long as you shave down your rear brake pads. Don't know about tire clearance.
(Edit - the text disappeared from my first post)
I'm not sure on maximums, but on my 2012 7.8 I am running an Aerocoach 75 and disc and there is plenty of clearance (19.6/24.7 int/ext).
Be aware of the duotrap bulge on the chainstay if going with a disc rear.
As for tires my experience with the stock bontrager wheels was I could fit 23c (GP4000s2) front and rear, possibly 25c on rear but the tire rubbed the underside of the brake on the front if I went up to 25c.
Practise doesn't make perfect, practice makes permanent. Only perfect practice makes perfect!
Re: Gen 1 Trek SC Max Rim Width [PrimalSteve] [ In reply to ]
Was there enough clearance for the Disc? On my Aeox and Speed Concept 9 (Gen 1), in certain conditions - heat/sunlight is my best guess - the disc expanded just enough to make contact with the DuoTrap bulge. I had a mechanic take a dremel to it and now there's plenty of clearance but... that's not exactly the orthodox way.
FWIW, on my SC 9-series, the biggest limiter is the front brake which, on a 7-series, is not an issue.
ZONE3 - We Last Longer
Its too wide. My training partner is on a 2014 7.8. Max rim width he was able to ride was 27.5 and a 25mm GP4000 which measured right about there as well.
