jspatrick wrote:
I'm not mechanically inclined enough to fully remove the 35a extensions and measure them...and overall having a hard time judging this since the base of the extension is enclosed in the subsonic bracket. I can see a "cut" mark but not sure what the length between the base of the extensions and the cut mark is. Is a 3 inch / ~75mm cut normal for these?Cutting the extensions drastically is pretty standard with the Subsonic, they're sized so that a tall rider with the pads forward still has options.
There is 40mm (~1.5in) adjustment capacity in the Subsonic bracket so you're not locked into one length. They do require more precise cutting than the Sonic bracket equipped bars. The reason for Canyon using the Subsonic is that too many people were shoving the extensions way back on the old J4 bracket and causing problems.
Speedtheory
