Hello!
two questions:
- with your solution, (I understand) that you will attach the aeropad and extension to the "tririg tilt kit", so... you could use another cuppads, like tririg ergo pads. true?
- tririg alpha x tilt kit it is not sold anymore in tririg, do you think that we could find and alternate solution?
I would be interesting in the 3d model to be printed of your adaptor.
Thank you very much
marcofoils wrote:
Thanks! You need the following
- TriRig Alpha X tilt kit
- Adapter spacer
- Transversal plate to suit your arm cups, BTA system, etc (made from a 3mm carbon plate in my case)
- A few nuts and bolts
I see that Shapeways now offers 40% glass filled PA12, that would be a cheaper alternative to CNC machining. The transversal plate is quick to machine. PM me and we can work something out.
