Shortening preexisting cranks
Is it possible to take my Shimano cranks that are 165mm and have some one machine them down to 160 or 155?
Re: Shortening preexisting cranks [teichs42] [ In reply to ]
If they are old solid shimano's, yes. If they are modern hollowtech II, no.
You also need to have a longer arm to start with, you don't have room to drill and re-tap in 5-10mm increments
My Blog - http://leegoocrap.blogspot.com
Ditto above. The pedal bolt diameter is about 15mm, so you would probably need a crank at least 20mm longer than your desired length to have enough material for a new pedal bolt hole.
No.
Re: Shortening preexisting cranks [jimatbeyond] [ In reply to ]
Thanks, everyone!
