Is there any reason that you shouldn't use your standard running shoes for weight training? For example, does the added weight break down the cushioning faster? I don't think it's an issue, but my dad asked me this the other day and I told him I had no idea, but I didn't think it was an issue. He was mostly wondering if he should have a separate set of shoes for the weight room and running.
Re: Running shoes for weight training [jhammond]
Fahgeddaboutit.
If you wear Hokas and do Crossfit, you would understand. You can hurt your ankle, knee or hip easily.
Reebok dominates Crossfit and weight lifting market and I've heard nothing but good thing about them. You should try them for yourself.
I have two sets of lifting shoes: Nike MetCons and Nike Romaleos.
I wouldn't use an active pair of running shoes. You shouldn't squat or deadlift in your running shoes either. You'd be better off barefoot.
Washed up footy player turned Triathlete.
By weight training, I'm assuming you are including squats, dead lifts, possible use of machines that require stable foot positioning etc. In this case, be careful using running shoes. Google weight lifting shoes and you will see shoes with a stable platform and a small wedge increasing from midfoot to heel. Very good for stability during lifting. If you a just working out on machines (not say a hack squat or an incline squat, where you require foot stability) then running shoes will be fine. I remember when combat boots were the rage for power lifters and heavy lifting, not so much anymore due to instability issues.
Not unless you are strength training like 5 to 6 days a week for an hour or more at a time.
I do track the workout as a treadmill run to log any mileage. I ditch my shoes for running at 300 miles. Some of my strength routines combine run intervals, so it's relevant to track the mileage as well.
If you're a crossfit junkie, I can see having dedicated shoes.
If you are an endurance athlete with 2 to 3 strength sessions a week, I don't see much of an issue.
Ryan
http://www.SetThePaceTriathlon.com
http://www.TriathlonTrainingDaddy.com
I got plans - https://www.trainingpeaks.com/...dotcom#trainingplans
Ryan
