2018 Cervelo R3 on trainer
The bike has a RAT style thru axle. What do I need to put this on the wheel on trainer?
Re: 2018 Cervelo R3 on trainer [s.gentz] [ In reply to ]
It depends on what kind of trainer you want to use. If it is a direct drive trainer that is compatible with thru axles, such as the Wahoo Kickr, you do not need anything. If it is a wheel on trainer then there are two options I am aware of. The first, is you can replace the RAT Derailleur hanger with a Cervelo threaded derailleur hanger (part# DRH-WMN112) and then use any 12mm x 142mm x 1.75mm through-axle adapter for a standard or direct-drive trainer. That comes directly from a Cervelo service bulletin. The threaded hanger can be ordered from a Cervelo dealer. The second option is using The Robert Axle Project thru axle for Focus bikes which uses the same RAT system. You can find it at https://robertaxleproject.com/...ner-focus-rat-bikes/. I have not used the Robert Axle Project axle but I have used the threaded Cervelo derailleur hanger with a Kinetic thru axle trainer skewer.
Brian Jacobson
Fit2Ride Velo Studio
http://www.fit2ridevelo.com
Re: 2018 Cervelo R3 on trainer [BrianJ] [ In reply to ]
Thanks for the response.
