Bike box Alan with a disc wheel
Has anyone travelled with a disc wheel in a bike box alan? Obviously you can’t use the strengthening pole on the middle.
Has it been on with a disc wheel without the pole? Any other tips to pack it?
Re: Bike box Alan with a disc wheel [IMF] [ In reply to ]
I have a VeloVault and this is a reason I am hesitant about getting a disc wheel because I fly to almost all of my races. The hard cases that don't have a pole seem to use thicker plastic. Would be neat if there was a secondary off-center location for the pole. That would help still be better than not having one at all.
Probably worth getting a separate case for the disc wheel, tbh
I've travelled with BBA and a disc without the pole - works fine, no issues.
Re: Bike box Alan with a disc wheel [iron snorks] [ In reply to ]
+1 been using BBA for trips to the PI and Canada + national travel without issue. The pole is a "nice to have" but the case is very strong on its own.
It should be fine. My partner and I have done ~100 flights with our BBAs. She normally has a disc, I normally don't. It's never had any damage. I don't think I've even used the stick with mine since ~2014.
Re: Bike box Alan with a disc wheel [ejls2] [ In reply to ]
Thanks all for the feedback
Old thread to resurrect but I found this on a search and have since discovered a product that might be helpful, so I thought I would share.
Velovault now produce the following extra support struts which are designed to work specifically with a disc wheel. In the case of the Velovault2 or BBA you would remove the integrated central strut and fit these instead. The only thing to then bear in mind is that when you pack the case you need to make sure these new struts do not foul against your frame and whatnot.
https://www.bikebox-online.co.uk/...heel-support-system/
https://velovault2.com/...-system-disc-wheels/
Cheers, Rich.
Re: Bike box Alan with a disc wheel [knighty76] [ In reply to ]
That's a neat solution. I wonder if there are any potential issues with the fact that it applies the load to the hub
