JB78 wrote:
ericMPro wrote:
aren't we overlooking the obvious that he's on a bike that's too small??
trentnix wrote:
Agreed - seat needs to drop 15-20 mm or so. And the cockpit should drop about the same and maybe 5 mm more. That's going to get you off the High-V.
Thanks. I’m 6”3’ and a 56cm frame.
I’ve previously had a 58cm P2C but felt way to stretched.
Even with this frame I have to slam to seat as far forward as possible to get remotely comfortable.
What do you observe as the indicators that the frame is too small?
Cheers
JB
The P2C and P5 have dissimilar geometries. It's why buying by size is, almost certainly, a good way to buy the wrong size. In a perfect world, you get a good fit and then buy based on fit coordinates.
Trent Nix
Owned and operated Tri Shop
F.I.S.T. Advanced Certified Fitter | Retul Master Certified Fitter (back when those were things)
