School me on Cassettes
So, I'm building up some training wheels, grabbed some Askiums from the Performance Bike going out of bidness sale. They were still selling cassettes for much higher than what you can get a Ultegra R8000 on Amazon.
The cassette that came with my Argon 18 E119 is an R8000 11/28 and there are a lot of other options I've noticed and it seems clear as mud. In the back of my mind I'd think an 11/32 gives more range but from what I can read that may not be the case.
Washed up footy player turned Triathlete.
Re: School me on Cassettes [TheStroBro] [ In reply to ]
Ensure your derailleur cage can support the largest cog you want. After that pick the range you need, especially if you’re going 1x. 52/36 or 50/34 with 11-28 would cover (best guess) 95% of the gearing range for any condition. Exceptions obviously for large front rings (descent from Hawi or anything in excess of 40mph) or dinner plate 58/60T TT use to mitigate chainline friction loss.
Edit: You can also play with calculator at http://www.bikecalc.com/speed_at_cadence to confirm your selection.
An 11-32 cassette does give you more range than an 11-28.
Funny: I picked up a 11/32 Ultegra cassette from Performance the day before yesterday for $40. I also picked up a couple of Castelli jerseys for $25/apiece. Pricing seems inconsistent across stores but there are deals to be had if you poke around a bit.
Do you feel like you need more than a 28 now? You should choose based on how your current cassette is working for you and the rides you anticipate coming up...
I switched my TT bike to a 11-25 when I bought it. I have rarely needed the 25, so I just switched it to an 11-23. I am doing Lake Placid 70.3 at the end of next year, so I will switch my TT bike back to the 11-25 or get an x-28 just for that race.
I have an 11-28 on my road bike so that it can be a great all-arounder. I have ridden it in a few rides with some very steep or very long climbs, and I have learned that an 11-28 is all I need for the worst climbing I have ever seen. I just switched my road bike to an 11-25 for better all-around riding. I have the 11-28 that I can easily swap back on if I need it for a ride with big climbs.
Re: School me on Cassettes [exxxviii] [ In reply to ]
I would say I'm fairly ignorant of this part of cycling, so when it came to building these wheels up I figured I'd ask. Your last paragraph gives me some ideas. I have ridden it like once since I picked it up from Moxie, so I couldn't say if I need anything more tbh.
What chainring(s) are you running up front? 50/34? 52/36? 53/39?
Typically, a 11-32 cassette would be for A.) Someone who lives in a very hilly region and needs the gears, B.) Is on a 1x cyclocross bike and needs a bit of range, or C.) Is 'older' and needs the easier gears to spin.
Re: School me on Cassettes [kppolich] [ In reply to ]
R8000 52/36
Apologies if I misread your post but it might be worth mentioning you don't necessarily have to get an R8000 cassette. Any Shimano or Sram 11 speed cassette is compatible. It's best to stick to road cassettes since mtb ones might go past the capacity of your rear derailleur. I'd check the capacity of the rear derailleur anyway.
I'd go out and ride up your steepest nearby hill before buying. 11-28 is a cassette with plenty of range designed for rides including hills. You may simply not need any more than that. Alternatives to getting a new cassette are 1) buy the tools to swap cassettes over - you learn a bit and could try the 28 you already own. 2) if you absolutely have to buy a bigger cassette now maybe get an 11 speed Shimano 105 or Sram Rival having checked your rear derailleur.
Do you have a long or short cage rear derailleur?
Short cage R8000 derailleurs can handle up to a 30T cassette
Long cage R8000 can handle a 34T cassette.
Re: School me on Cassettes [OddSlug] [ In reply to ]
This was more a fact finding mission. Sitting in my cart on Amazon is an 11/28. There are some hills around here that I ride up and down frequently...or rather was: Usery Pass and Hunt Highway.
I already have the tools to change out my cassette as the once used Wahoo I picked up had a SRAM 10 S on it and put the Shimano 11 S back on it.
The stock 52/36 & 11-28 that came on your bike is a nice setup. Plenty of range on both ends. If you think you need an even easier granny gear, go with the 11-32, if you don't want to worry about it and want the same setup on your training wheels and race wheels get another 11/28. I believe the stock R8000 regular cage derallieur can handle the 11-32, no need for the mid/long cage Rear Der in order to run the 11-32.
Have you noticed riding the 11-28 on your other wheels that the gear jumps are large? Maybe a nice 11-25 or 11-23 would give you smoother gears without the jumps. I don't know where you live, so the terrain and typical riding conditions come into play. If it were me, 11-28 on everything.
I prefer this gear calculator to the one above:
http://ritzelrechner.de/
the current options under discussion:
http://ritzelrechner.de/?GR=DERS&KB=36,52&RZ=11,12,13,14,15,17,19,21,23,25,28&UF=2135&TF=90&SL=2.6&UN=KMH&DV=teeth&GR2=DERS&KB2=36,52&RZ2=11,12,13,14,16,18,20,22,25,28,32&UF2=2135
<edit: that gets cut off. Quote my post and it should bring up the full string to copy and paste>
11-28 is a good allrounder, provided it can comfortably get you up the biggest hill you'll face.
11-32 will give you one more lower gear (14% slower than the 28), with the same top end.
The downside to the wider range is different jumps between gears in the middle of the cassette. Not a dramatic issue with 11 speed though, but you do lose the 15T sprocket.
NOTE:
THe RD-R8000-SS (short cage) is officially only rated to 30T max on the cassette.
The RD-R8000-GS (medium cage) is rated to 34T max.
Shimano do tend to be conservative though.
Finally. It seems I'm not crazy after all. I've ridden 11-25 for years, with 52 or 53/39 front chainrings. And I keep reading about 28 and 32 cassettes, and I'm like "am I nuts"? It's not crazy hilly here, but not flat either - there's some nasty steep rollers. And yet I hardly ever need to go into to small ring. For giggles I got myself an 11-28 this year and the 28 is still spotless. I'm going back to 25 on that wheel as well.
Citizen of the world, former drunkard. Resident Traumatic Brain Injury advocate.
Re: School me on Cassettes [Richard Blaine] [ In reply to ]
The gearing needs of different riders vary pretty dramatically. The strongest cyclists are several times more powerful than the weakest. On steep hills, where gravity is the dominant resistance force, that results in the strongest cyclists being several times faster than the weakest. Preferred cadences don't vary by anywhere near that much across cyclists, so some cyclists have use for gears twice as low or more than what some other cyclists have use for, even before accounting for variations in regional hilliness.
Re: School me on Cassettes [TriFluid] [ In reply to ]
Always surprised to find when I go riding with triathletes, how many DON'T seem to understand this and ride on completely crossed up chain-lines!!
I kindly try and help out explaining that forget gears, power and all the stuff and think about running as straight a chain-line as you can in every situation when riding!
Steve Fleck @stevefleck | Blog
Re: School me on Cassettes [Fleck] [ In reply to ]
Anyone actually spend the premium for the DuraAce cassette? I recently found one sale and got it for my race wheels. Still double the cost of Ultegra, but about 50 bucks cheaper than I had seen it anywhere before. Don't really know if it's at all worth it. I've heard they wear faster. But this will be on a race wheel that might see 250 miles a year. Had the money earmarked for the bike anyway. Realize weight isn't a huge deal on my tri bike, but it never hurt anyone to shed it either.
Re: School me on Cassettes [KG6] [ In reply to ]
This is the perfect application for a Dura Ace cassette.
Just be sure to check things out with a test-ride before the actual race, to ensure chain is not too worn ( or measure the chain) and still works with the DA cassette
I ride inside now, so the plan is to actually have a dedicated waxed "race chain" as well. My previous cassette (Ultegra I believe) will stay on the trainer along with a separate chain.
Someone say "cassettes?"
"What's your claim?" - Ben Gravy
"Your best work is the work you're excited about" - Rick Rubin
Re: School me on Cassettes [RandMart] [ In reply to ]
Randy, sometimes I wonder if I'm the only one laughing at (or otherwise relating to) your punk rock jokes.
That cassette is classic - "Home taping is killing record industry profits - we left this side blank so you can help".
Of course forgetting that while they're busy killing the record industry, they are still helping "big cassette", "big guitar amp", and "big drumstick"
I like to think of them as "observances" or "recollections"
I said I'm not just laughing at them, I'm relating to them as well.
Yeah, we're not alone ... check out the Wattie Ink thread, for example, or some of the music threads in the LR
There's nothing complicated or mysterious about this. 32 teeth is more than 28 teeth and they both have 11 at the other end. An 11-32 does give more range than 11-28. Pretty simple.
The only reason you may not get more range via a simple cassette swap is if something else in your drive train was preventing you from using those extra teeth. For example if your rear derailleur doesn't have sufficient capacity or your chain is too short.
However, more range is not necessarily better. It depends on such factors as where you ride, how you ride, your ability, your weight, whether you're willingness to change setup between rides, whether you favour nominal setup for most common routes over flexibility of setup for all potential routes, etc.
I occasionally ride my Tri bike in the mountains but usually bring my road bike. I don't mind switching cassettes for special occasions but don't bother doing it every week. I'm fairly heavy for a triathlete (usually over 80kg, except at my leanest mid season on good years!). I don't mind a low cadence but don't like being forced to high intensity on long hills late in a long ride just because I have insufficient gears to do otherwise.
I used to use 50/34 and 11-28 on my road bike but put on a 11-32 cassette for climbing Gallibier, Glandon and Alpe D'Huez in the Alps last year. It turned out I didn't need that gear but it was nice to have it just in case my knees started suffering. I planned to switch back when i got home but actually never bothered. With 11 sprockets, I don't find myself missing the smaller gear ratio spacing and that small gear, though not essential, does come in handy now and again on steep climbs.
On the Tri bike I've got 52/36 chainrings and generally use 11-25 as it spends most of it's time on the trainer or riding flat or rolling routes. However I've used 11-28 in the past for hillier courses and it is only a 5 minute job to switch.
Unless you're new to cycling, or plan to ride a route that's dramatically different to what you're used to, surely you already know what gears you want/need?
Bear in mind that so long as you have the ability to switch cassettes, and if you do a lot of riding, there may not be much additional cost to having more than one cassette. You'll be spreading the wear and tear around and they'll obviously last longer if you're using them less because duty is shared.
