Yellow wrote:
Mdiaz wrote:
NickMa wrote:
I'm 186cm and legs are 92cm, I ride canyon speedmax slx in size M.
Feel good, L definitely would be too big. It seems that Canyon bikes come little bigger than the competition... I've been riding M for my whole life (175cm) both road and TT, but the recommend me to go with an S when it comes to the Speedmax. It depends on the stack and reach you want to ride:
- In both the 2018 and 2019 frames, there is a choice of stem (65mm or 85mm) that changes the reach range possible.
- In the 2018 frames there is choice of 3 base bars and because of where the pads / spacers mount that changes the stack ranges possible on each.
- In the 2019 frames, the arm rests mount to a central pedestal, but the stack range is smaller and with a like for like "flat" 2018 base bar also a bit taller.
- As noted above there is a team switch plate kit that allows the 2018 arm pads to be both narrower and less reach. There is also an angled spacer kit both of which are ordered when you configure the bike.
- The 2018 bikes have a 1-piece bottle, the 2019 bikes is 2 piece that joins under / through the arm pad pedestal.
In my case for stack = 620, reach = 509, bb-saddle = 809 (albeit I raced this season at a reach of 533. I'm 181cm tall, but long limbs):
- 2018 medium, 85mm stem, flat bar and pedestalled up quite high. With the longer reach I rode this year, it would be the absolute max reach possible.
- 2018 large, 65mm stem, drop or the flat bar with relatively few spacers. On the flat bar I cant go down much (~15mm max), the drop bar I'm very near the middle of window, but would need the team switch plate for less reach. (Actual reach without the switch plate when set like this should be 511).
- 2019 large does not fit as too much stack. 2019 medium would fit with the 85mm stem and pedestalled like the 2018 bike.
Anyway I actually ordered a 2018 large, 65mm stem, drop bar and the various accessories. The one-piece bottle and a front-centre much closer to what I like / am used to riding swung it for me. The other bike that would sensibly work for me is a Trek SC, but all depends on your fit. couple of things. first, it's much easier if by "stack" and "reach" you say what you really mean. is it "pad stack"? if so, please say it, because "stack" means something entirely different.
second, mdiaz is right. canyon bikes are "bigger" than the competition, if by "bigger" what is meant is that a canyon in size small is "bigger" than other bikes in size small.
canyons are "bigger" not in height, but in length. however, it's the length that matters, because the height of a canyon, in an SLX, is quite adjustable. you can - as you know - change the pursuit bar as well as the pads, and quite liberally. you can change the length as well, for fit purposes, but you can't change the wheelbase, and specifically the front-center. you can change nothing below the head tube.
for this reason, i'd ride a size L in a speed concept but a size M in a speedmax. this isn't just a speedmax thing. i'd also ride a size M in a dimond.
you all are about to get a little help on this. because of the heavy interest in canyon tri bikes here, and because canyons are about to become a lot more available in the US, and because this is a consumer-direct brand, and you don't have your LBS in the middle guiding you (which may be a good thing, actually, depending on your LBS), i've enlisted some help in matching you to the canyon you need. this will become apparent to you all quite soon.
Dan Empfield
aka Slowman
