Notio Konect wrote:
Hi,
To us and our testers, ''works'' means a CdA precise enough to select their gear with the testing results. They were able to select between several helmets and clothing. The Notio Konect was also used to improve their position on the bike.
The main advantage is to be able to test on the road in real conditions. The wind tunnel and the track are great tools but it is not the same feeling as to test on the road, especially when you want to tweak your position.
regards,
Pierre-Andre Boulay
Notio Konect Product Specialist
Hi Pierre-Andre,
Thank you for posting here. I don't disagree with anything you've said, however for us (the consumer) "works"
also means that it works all the time without drama, without a lot of messing aroundm and without having your engineers there with a pro team to make sure it's working properly. When we need customer support it's there, and when we need warranty support it's there. To use the Garmin Vector 3 pedals as an analogy. By your definition, they work. By many peoples' definitions here, they don't work very well at all. We're all hoping that this device works, in every sense of the word. Best of luck to you.
