If the bolts holding the brake cover on are too tight it causes the cover to flare out. Try backing the bolt out a bit.
Re: Official Giant Trinity Advanced Owners Thread [TulkasTri]
Re: Official Giant Trinity Advanced Owners Thread [dfroelich]
Thank you.
Looks the same as the Tri version?
Is this the new box? http://www.giantbikespares.com/...oduct_detail/3-42757
See the notes, it says will not fit the TT. I wonder if there's a slightly different spacing on the bolts. I'm wondering if that's the case if an adaptor could be fabricated.
Close up pics of your front end would be nice :) . As I said above info is very sparse on these bikes.
Check this pro one out. smooth top tube so no box at all and only a 2 piece "nose" section under the stem. Is that down to a smaller frame size (mine's a large) http://www.cyclingnews.com/...llery/#disqus_thread
Oh and thank you for aging mine. No online resources available to accurately date it or was the 16 and 17 identical?
Thanks
Dan
Thanks
Dan
Re: Official Giant Trinity Advanced Owners Thread [Livelee]
Yes, that is the right bottle!
Without actually trying it out, no way to know what the reasoning is why it wouldn't work on your TT frame. I'll go out there and shoot a bunch of pics shortly.
Thank you
That’s very kind.
That’s very kind.
Here is a quick collection of the front end: https://photos.app.goo.gl/kzVsJEfPWCvuq7z43
Let me know if you could use anything else!
Thank you. That helps. I think / fear I may need a new stem. Forks looks like they are in a similar place. I wonder if the bars are the same?
Is your frame a medium? I'm wondering why I have 3 spacers on the nose and you only have 2.
Thanks
Dan
Thanks
Dan
Livelee wrote:
Hi Greg. Thanks for the link. Do you ship internationally? (i'm in the UK) How does your bolt mounted box compare to the stock one from Giant?
Many Thanks
Dan
Hi Dan,
Yes, you bet, we ship internationally (including to the UK) all of the time. To make a comparison, do you have any info or images of the stock bento from Giant? Our strap mounted and bolt mounted packs are a different design from the hard sided packs from other manufacturers, but we have many photos of our range on our fb page and instagram (see links in signature). But if you have any other questions, please don't hesitate to message or post again.
thanks,
Greg @ dsw
Re: Official Giant Trinity Advanced Owners Thread [DarkSpeedWorks]
Thank you. The cost of the official one that's "good" is very cheap so I might buy that. Unfortunately I know nobody else with a Trinity. Before I found this forum you'd think the bike never existed!
Re: hydration. I'm going to buy one (front bottle) and see what happens. Unfortunately the mounts are not listed so my supplier needs to goto Giant directly and ask. I need some bolts too that the previous ham fisted bike owner seems to have butchered!
I'll update this thread for future info if I can get the bits and make them fit. It might be useful for other TT owners.
Cheers
Dan
Cheers
Dan
Re: Official Giant Trinity Advanced Owners Thread [JVanderveen]
Hey guys I've recently bought the trinity advanced pro 2 2017 and am having trouble simply disconnecting the front hydration box to give it a good clean from the old left over sticky sports drink left inside on a previous ride. I can see there's an arrow which indicates putting pressure down with your fingers to give it a bit of a good shove but i feel like I'm not doing it right, feels like any more pressure and its just gonna snap! Any advice welcome! cheers.
Re: Official Giant Trinity Advanced Owners Thread [Rubix]
Is it the new style bottle that has the slide out bit on the bottle of the bottle near the tire?
If so, it is a super snug fit. I pry it up from the back with a flat head screwdriver. You can wrap it in a little tape so it won't scratch.
Re: Official Giant Trinity Advanced Owners Thread [cyclenutnz]
So if I have a regular Trinity Advanced, not the Pro...what would have to be done to install the stock front mounted hydration bottle on the Pro?
Washed up footy player turned Triathlete.
Re: Official Giant Trinity Advanced Owners Thread [TheStroBro]
It would be hard to guess without having both on hand to tinker.
Where are you located? Perhaps someone is close enough to help test.
Just to reiterate, you want to install a front hydration bottle that comes on the Pro version onto your Trinity (non-pro) version?
In that case, I'd abort because the mounting bracket is built specifically for the AeroDrive Tri bar and stem found on the Pro. The non-Pro version uses a significantly different fork and stem which will render the bracket useless. My recommendation would be to use one of the very capable and aero models from Profile Design or similar.
JVanderveen wrote:
Just to reiterate, you want to install a front hydration bottle that comes on the Pro version onto your Trinity (non-pro) version? In that case, I'd abort because the mounting bracket is built specifically for the AeroDrive Tri bar and stem found on the Pro. The non-Pro version uses a significantly different fork and stem which will render the bracket useless. My recommendation would be to use one of the very capable and aero models from Profile Design or similar.
I'm currently using the Profile Design FC35. I just wanted to know if it was possible without too much sweat even knowing the differences in Forks.
TheStroBro: Mar 14, 18 16:37
If its the Gen2 front hydration bottle you need to lift the triangular plastic piece on the top back part of the bottle that secures it to the stem. The arrows indicating downward pressure is how you install it. I often have to use a screwdriver to help if its been left in a sticky mess.
I'm sure there's a way to make it work with some creative thinking, but I think that FC35 option probably fits more clean than the Pro bottle ever would on your bike. I'd stick with that option as it's a really good one!
I doubt you'll get the official bottle on it, the stem is completely different.
those Giant bottles just dont comfortable enough. Hard to take off, hard to wash properly, the sraw is too low.
I tried two of them, and switch to Xlab torpedo. Much better, but not looks so cool )))
Re: Official Giant Trinity Advanced Owners Thread [Evgen]
I’m considering the FC35 unless someone can convince me there’s a better alternative?
Hi now a trinity advanced pro owner
looking at how i now ship to races ,spent a bit of time searching youtube & forums
i am used to using bike bag a simple bike bag i had for some time or old fashioned cardboard bike boxes etc
do not want to spend £000,s on a box/bag for 2 ish races overseas a year
any in situ photos of bars removed etc would help
How many have purchased a new saddle?
Just did...dash. haven't received it yet.
Does the new bento box fit the 2016 Trinity? (Sorry I missed this if it's already been mentioned).
I don't like the flip-tip one on my 2016, it gets snagged on my leg sometimes and flaps open, annoying.
Re: Official Giant Trinity Advanced Owners Thread [Super D]
Super D wrote:
Does the new bento box fit the 2016 Trinity? (Sorry I missed this if it's already been mentioned). I don't like the flip-tip one on my 2016, it gets snagged on my leg sometimes and flaps open, annoying.
Yes, it fits.
You can actually go to your dealer and they will order it for you. Many of us have done this and it was no charge.
The new bento is waaaay better. You will be happy with it. The original one was pretty much worthless.
Also, the new front bottle is improved as well - bigger volume, better attachment clamps. (When I took this bike for a test ride, the front bottle launched, so I always used gorilla tape on the side to keep it secure. The new bottle is overbuilt and cannot launch. It actually takes some effort to remove after a ride - great.)
dfroelich wrote:
Yes, it fits.
Sweet, thank you.
