Re: Choice between the new ENVE SES Aero TT system or the Profile Design Aeria Ultimate. Which would you choose? [cyclenutnz] [ In reply to ]
Man, the whole package looks so slick.
Re: Choice between the new ENVE SES Aero TT system or the Profile Design Aeria Ultimate. Which would you choose? [paulmartin] [ In reply to ]
paulmartin wrote:
Would love to see this mounted on a felt IAx..
Am I reading that the bottle fits better with the 100mm stem?
Do we know if much testing has been done on rough roads with these? I had a garmin bike computer go flying at frankfurt this year when my torhans mount snapped :(
I'm also curious if anyone has had success using this on a Felt IAxx, particularly with a TriRig Omega brake.
Re: Profile Design Aeria Ultimate aerobar and stem [cyclenutnz] [ In reply to ]
cyclenutnz wrote:
kart17 wrote:
I have an Ordu OMP as well and considering this setup although my one concern is the brake and also getting my stack and reach right.
What size is your Ordu and what is your pad XYZ (to rear centre of pads, including cushion)?
Size Medium Ordu OMP
My coordinates are:
X: 460 to center of pads. I have experimented going to 480 by moving the pads forward it doesn't really bother me.
Y: 620 to top of pads.
which BTS bottle holder is that?
cyclenutnz wrote:
Beard only works with Aduro bar/stem. Bottle only works with AU stem, so you can't have both. Not that you need both as shown below.
Astrid hadn't cut the gusset to match her head tube cleanly, she just has the brake covers, no beard.
You don't need the AU bar, just the stem. Which fits fine with original Aeria.
Eric Reid
AeroFit | Instagram Portfolio
Chapel Hill, NC
Aerodynamic Optimized Bike Fitting, Retul Pre-Purchase Bike Fitting, USAT Level 1 Triathlon Coaching, Nutrition
Ask me: Scody Optimized Speed Suits | CeramicSpeed Oversized Pulley Systems | HUUB Skinsuits and Wetsuits | Ventum Bicycles and Frames
Re: Choice between the new ENVE SES Aero TT system or the Profile Design Aeria Ultimate. Which would you choose? [ericMPro] [ In reply to ]
I can't tell. I'd normally put an RM10 on a cervelo. But it might be one of the chunkier models like RML
Velogicfit bike geometry comparison l Speedtheory
Re: Profile Design Aeria Ultimate aerobar and stem [kart17] [ In reply to ]
I took off 40mm to convert to pad x(rear)
To clear the TR brake on your size frame you really need the long stem, which is at the very limit of rearward adjustment for the above position (so it doesn't show in the results as the search is designed to not show extreme setups)
But can easily with your 480 Padx-centres
Re: Choice between the new ENVE SES Aero TT system or the Profile Design Aeria Ultimate. Which would you choose? [robegan99] [ In reply to ]
The stem fits, but I'm not liking the look of the clearance for the bottle with the nosecone.
Is that the 70mm or 100mm version?
Thanks!
Re: Choice between the new ENVE SES Aero TT system or the Profile Design Aeria Ultimate. Which would you choose? [The GMAN] [ In reply to ]
Finally have the stem, bottle, and eTap blips/clics/wires and Torhans Bento X installed as best I can. Had to do some dremel work on the Dimond Aero Box to fit the clic/blip wires to guide them into the Bento X. The Blip Box is in the Bento X.
2020 Races:
Ironman 70.3 Musselman, Ironman 70.3 Panama, Ironman Chattanooga, Ironman Arizona
Favorite Gear: Dimond | TriRig | Desoto Sport | Hoka One One
Nice. Thanks for the photos.
Is it me or is the bottle ever so slightly bent to one side?
Re: Choice between the new ENVE SES Aero TT system or the Profile Design Aeria Ultimate. Which would you choose? [frenchieTT] [ In reply to ]
I might need to more center my stem to the steerer tube.
2020 Races:
Re: Profile Design Aeria Ultimate aerobar and stem [The GMAN] [ In reply to ]
I tried it on my Andean.
Doesn't clean up the stem area as well as the DB stem.
Wanted the chance to change the basebar/aerobar, but looks like I have to go back.
Not a fan of the flipping aerobar pads.
Re: Profile Design Aeria Ultimate aerobar and stem [campled] [ In reply to ]
Do you maybe have a picture of the entire Andean with the PD system on there? Just curious how it looks since the bike already looks like a spaceship
Re: Profile Design Aeria Ultimate aerobar and stem [Tri_Joeri] [ In reply to ]
I already removed it and put back the DB stem/ HED Corsair combo.
Managed to take a pic when I was still retrofitting the other day.
Where is everyone getting the bottle from?
http://www.clperformancetraining.com
http://www.pillasport.ca
Re: Choice between the new ENVE SES Aero TT system or the Profile Design Aeria Ultimate. Which would you choose? [al-gorithm] [ In reply to ]
As far as I know, no online retailers have it right now. I had my local shop order it from PD or you can order on PD's website.
Hey fellow Dimond owner. I like the integrated bottle but you would be better with a true bta with the mantis position. The arms angled up with the gap filled force the air around the body but with your arms so wide the air will travel right through hitting the torso. I have just gone similar position myself so have been doing a lot of research. I am using a vision bta bottle that has a fill point right at the top that you can use when going mantis like position.
Re: Choice between the new ENVE SES Aero TT system or the Profile Design Aeria Ultimate. Which would you choose? [Shambolic] [ In reply to ]
Alternately. Just get those arms shoved together. Looks possible to me with those parts.
Re: Choice between the new ENVE SES Aero TT system or the Profile Design Aeria Ultimate. Which would you choose? [chicanery] [ In reply to ]
That is the other option but comfort goes out the window IMO and a big part of finding best position especially for IM
Interesting. I have found the opposite in arms up. The closer, the better.
I'm squeezing my bta hard but not forearms together to close the gap. Each to their own...
Bottle out front is miles more aero, and then your arm position can be more flexible.
How have you tested this?
I'm not sure why I made the comment that I need to center my stem to the steerer better because the whole system moves as one then.
Yes, the bottle does aim more to one side. Which is going to make my math brain of symmetry and congruence go crazy.
2020 Races:
I've found this as well but I always go hands closer than elbows. Internal rotation helps greatly with shoulder discomfort.
