- around 2:25 +/_ / 100 yards slow, just swimming, no aids. I have been told my stroke, breathing, head position, catch, etc. etc. is okay, BUT, my butt is too low, in the water too deep, same for calves and feet. Legs/butt/feet are not on the surface of the water enough- dragging /slowing me down. Okay I see that. How do I get that part of the body to ride higher in the water? Swim downhill, press the chest down, belly button against spine, lift feet to surface. Okay I see the theory of that - though I don't seem to be making much positive progress in accomplishing that . At this point, fins and my "weak" kick don't do the trick. Solution ? ---- use something to lift said part of the body - pull buoy or buoys . Seems logical to me. One pull buoy gives my about 2:15/100 yards. More leg float - 2 pull buoys gives me about 1:50 /100 yards. That's more like it.
1. It seems like to me, the pull buoys and my increased speed confirm the need to get those legs up higher. DO YOU ALL AGREE WITH THAT CONCLUSION?
2. If it was possible, do you think the equivalent of 3 pull buoys would increase my speed even more? or is there a point where higher and higher legs don't make any difference and actually start to slow you down?
3. What else can I do (drills ? ) to get those legs up without pull buoys?
