Any details on the aerobar risers? They are hinted at in the images, but not mentioned here or the crowdfunding site.
Re: Culprit Covert Op Aero Stem and Clip on Aerobars, P.E.R.K. saddle/tool bag on indigogo [culpritbicycles]
What's the stem angle?
WTB Broken eTap Blips --->http://forum.slowtwitch.com/.../?page=unread#unread
FS : 2008 56cm Cervelo P3C ---->http://forum.slowtwitch.com/..._disc_cover_P6553661
Re: Culprit Covert Op Aero Stem and Clip on Aerobars, P.E.R.K. saddle/tool bag on indigogo [shoki]
Yes, Di2 fits inside the cover
Re: Culprit Covert Op Aero Stem and Clip on Aerobars, P.E.R.K. saddle/tool bag on indigogo [dangle]
Yah
I will update video next week. My samples of spacers came after my video shoot. So sent to vidoegrapher to do a video of actual product stacked, etc,
The spacers are designed to tuck di2 icable n the back pushed in place.and a cable holder clip Part A of B should also work from jagwire allowing mechanical to be clipped in before going into stem keeping cables hidden from the wind from the front.
Will offer 5mm, 10 mm, 20 mm, 40 mm, 60 mm, 5 mm bridge.
0-80 mm total. However. each stack is 4 bolts. So thats my concern shipping weight right now.
Will discuss internally this weekend and see what options we have to include in shipping and at what price increase.
Waiting on final bolt pricing as well
Cheers
Joshua
Cheers
Joshua
Re: Culprit Covert Op Aero Stem and Clip on Aerobars, P.E.R.K. saddle/tool bag on indigogo [gary p]
Gary
It is a cornerstone for Tri bikes but I am also catering to the road market with this stem. Which is why I didn't design BTA mount into cover.
Road and tri market is heading to fully hidden cables. My patent helps keep this stem unique in that it is an open faced design with accessible cables at all times, easier for travel and assembly which should be an option I hope to sell OEM spec to road and tri brands.
Besides. we all hope Sram actually improves the blip box.
Re: Culprit Covert Op Aero Stem and Clip on Aerobars, P.E.R.K. saddle/tool bag on indigogo [soldagreen]
Extension length, Alloy 365 mm, carbon 384 mm
Could you show us a picture og how the cable runs go without the stem top cap? Interested to see if I can run mechanical on it...
Re: Culprit Covert Op Aero Stem and Clip on Aerobars, P.E.R.K. saddle/tool bag on indigogo [davidalone]
Here you go , cover off
Re: Culprit Covert Op Aero Stem and Clip on Aerobars, P.E.R.K. saddle/tool bag on indigogo [gmh39]
Stem angle is -10 degrees
Bummer I was about to pull the trigger today. I was hoping it would be -17 I wanted to switch this out with my current stem but with the -10 according to ttbike fit stem calculator it would raise my stack 12mm. If anything I would be trying to at least stay the same or lower. I am curious why the -10 for an aero stem? maybe I am wrong but I thought -17 on most tri bikes is what is most common. Did you try to find a middle ground for road and tri bike use?
Re: Culprit Covert Op Aero Stem and Clip on Aerobars, P.E.R.K. saddle/tool bag on indigogo [mknight84]
Mass market appeal
most common on road bikes is -6 to -10 or even positive rise for some. Tri bikes you sometimes find -17. But honestly not many stems are -17 on bikes as the average rider doesn't ride that agressively.
Had to choose an angle that would be best for both road and tri. And had to study what was on the market to compete against and those were PRO missile and 3T integra both at -10.
Sorry we were not able to meet your needs.
. if we fund, a different angle is definitely in the plans but Tri market is really small compared to road segway and I want to see this product on OEM spec for road bikes and tri bikes with fully hidden cables, while still allowing athletes the ability to travel with the bike with handlebar removal.
Also, biggest cost is the cover in tooling. So that is a limiter and reason for the high funding goal. It allows me to keep the unit pricing retail reasonable at 110 USD with lower unit cost but higher up front tooling costs. This also means opening more sizes and angles comes at a very high mold fee. So had to choose one that works well rounded for all.
If you need extremely low. The profile Ultimate Aeria(my direct competition) is I believe -22 degrees, so should help you reach your fit numbers.
Hope that explanation is clear. Thanks for your honesty
Thanks for the reply. Totally understandable. I hope this works out well for you. If you do offer other angles in the future I will definitely pick one up.
I uploaded an install video of the aerobars
Shows how easy it is to set up and adjust.
https://vimeo.com/241989692
very nice.
Do you think one could run
One could run??' o don't understand
Is it possible to order without any extensions? I have a preferred setup that I would like to use with your clipon so don't need another set of extensions.
fyi the timeline makes it look like it won't be shipping till 2019 (eventhough it says elsewhere on the page that it will ship in 2018)
I love this stem. Am now a backer. Will be updating my set up this spring me thinks!
NCCP certified Comp coach
Re: Culprit Covert Op Aero Stem and Clip on Aerobars, P.E.R.K. saddle/tool bag on indigogo [HoustonTri(er)]
Yes,
I will add that perk option in. Unit price wont be much different as the cost of extensions is lowest price of the design.
Re: Culprit Covert Op Aero Stem and Clip on Aerobars, P.E.R.K. saddle/tool bag on indigogo [aeroyoost]
Timeline shows 2018. Can I ask where the date 2019 is coming from?
Thanks
Joshua
Thanks
Joshua
From the timeline you posted, it seems that the starting point in October is October 2018 and shows the products being shipped in 2019.
Re: Culprit Covert Op Aero Stem and Clip on Aerobars, P.E.R.K. saddle/tool bag on indigogo [cloy]
I see now
Will update later.
Tks
Will update later.
Tks
culpritbicycles wrote:
Should work on felt iaxx I dont have access to one to check. Felt hasn't seen 3d to verify. But longer stem has 2 cable stopd so should be able to run inner cable to front brake.
So, either I have that dimension wrong or you've already ruled out most people's Felt IAxx as a candidate for this stem. A shame as it does look like it would have been a very interesting option.
Re: Culprit Covert Op Aero Stem and Clip on Aerobars, P.E.R.K. saddle/tool bag on indigogo [Ai_1]
29 mm is above headset top cap right?
Does that include the expander plugs height added in? most expander plugs are 2-3 mm added height.
I just remeasured and it should work but I don't have an IA xx available to me in Taiwan to check.
Kiley has a stem for review., I'll see if he can check locally. unsure if he can though as he has a build ready for it to use for testing.
I'm not looking to start a war here, but any aero comparison to Tririg's Alpha X? I'm running a stock cockpit on a 1st gen speed concept and I'm looking to upgrade for aero gains. I'm torn between a used Alpha X and your stem/aero bar set up with a 3rd party base bar.
