NIB Argon 18 E119 Tri + Frameset.
Price: $5,000 (MSRP is $5,750)
Overview:
- Aerodynamic gain of 14.89% over the E-118 Next
- Exclusive rear E-119 Tri brake - Cam-pulled system installed horizontally; aerodynamic, easy to access and adjust
- Concealed front E-119 Tri brake - Ultralight and easy to adjust
- Triathlon-adapted geometry, 78º seat post, and adjustable saddle position (+28mm; -28mm) - Creates an optimal fit for any level of athlete
- Carbon lay-up even lighter than the E-119 Tri’s - Designed for highest performance and stiffness
- Exclusive integrated handlebar with our ONEness concept - Offers greater headset adjustment, optimal aerodynamic positioning, and more than 30 configuration options
- Additional 25mm tire clearance - Prevents the brakes from rubbing and enables faster wheel changes
- CFD analysis (wind tunnel and velodrome testing) - Optimal aerodynamics in true wind conditions (5° to 20° yaw angles)
- Classic derailleur hangers - Makes for easy wheel changes
- Travel-friendly - No complicated hardware, easily removable cockpit and wheels
- Size-specific geometry - Well balanced ergonomic fit for every frame in every size
Argon 18 E119 Tri Plus Frameset 2016 Specification
- E119 Plus Carbon Frameset
- Full Carbon Fork
- Carbon Seatpost ASP-7050
- Colours Black/Grey
- Bottom bracket: BB86
- Headset: FSA MR122 and MR136 bearings + oneness 3.0 compressor included
- Removable and adjustable front derailleur hanger compatible with compact and oval chainrings
- Forged dropouts with replaceable forged rear derailleur hanger
- Exclusive Argon 18 integrated aero brakes
- Triathlon accessories (nutrition, hydration, and survivability)
Pure Grit Multisport; Triple Threat Triathlon
