Lawyers - how is this possible
https://www.theguardian.com/...-public-vinod-khosla
Is it that there is a right of way across their land that they have stooped access to or are they just blocking public access roads
How does someone get away with this? What would their justification be legally?
Re: Lawyers - how is this possible [Andrewmc] [ In reply to ]
Not a lawyer. The same issue has happened along Lake Michigan in places with a landowner blocking access to old public roads or discouraging in other ways by putting up signs or planting things in the way of the old road. They file lawsuit after lawsuit in townships with little money until they get their way.
Thankyou surfrider foundation
They constantly try to escape from the darkness outside and within
Dreaming of systems so perfect that no one will need to be good T.S. Eliot
My understanding is there are public right aways i.e. de facto easements on the properties that allow the public access to the beach. Also some of the asshats kick people off the beach.
David Geffen (and other homeowners) in Malibu have tried pulling the same shit. Typically they buy properties and gate off the existing right-of-way crossing them, essentially blocking public access to the beach.
What windywave said. The CA has what's called the Coastal Act, which essentially says (almost) the entire coastline must remain publicly accessible. You cannot use your private property to create your own private beach by blocking access.
Re: Lawyers - how is this possible [trail] [ In reply to ]
What happens if you cut the lock on the gate to get access to the beach you are entitled to access?
What some NJ coastal communities pull to get around this is to restrict public parking anywhere near these public access points or jack up beach badge fees and make it difficult to actually get a beach badge.
Pretty much all of those efforts are shot down in court, time after time (thanks to surfer lawsuits, mostly).
"Go yell at an M&M"
Re: Lawyers - how is this possible [len] [ In reply to ]
Misdemeanor mischief?
Re: Lawyers - how is this possible [klehner] [ In reply to ]
I know in Hawaii the hotels have to provide some limited parking so you can access the beach. But its like 6-8 spots in a parking lot for several hundred at times.
Re: Lawyers - how is this possible [WelshinPhilly] [ In reply to ]
If there is a public right of way why do people just not going down and remove barriers? What legal right can the owner invoke to stop them? If police are called is not the owner liable for blocking it? Hoe can it be trespass?
Andrewmc wrote:
https://www.theguardian.com/environment/2017/aug/10/martins-beach-california-public-vinod-khosla
Does this vary by state? I thought you owned the land above the high tide mark. I.e. people could walk along the beach or in the water, but not above the high water mark. and they could only access it from public access points and not walk through your property (unless of course there were public easements.) Does it not work this way?
The barriers are usually gated walls/fences. The right-of-way is likely quite small and nothing prevents a property owner from walling off his/her land from the masses. Likely, the gate across the right of way is put up appropriating the ROW for the property owner's own benefit. The police will not break down the walls or gates, but they likely will cite the property owner, but for those guys, a citation is nothing. They'll pay them ad nauseam because they're not criminal in nature and are chump change. The only way to get the gates down is to file suit like Surfrider did.
''The enemy isn't conservatism. The enemy isn't liberalism. The enemy is bulls**t.''
—Lars-Erik Nelson
Re: Lawyers - how is this possible [patf] [ In reply to ]
That's pretty much how it works on Martha's Vineyard (and i think in the rest of Mass. as well). In addition, there are some beaches that have restricted access during the high season but are more generally available outside the summer months.
The public trust doctrine is generally that the sand below the mean high tide line is held for the public. In addition, even though there are areas where the land above the mean high tide line is privately owned, the public still has some rights to cross that land for access.
I don't believe that an individual gets to choose where the access point is. That's a complicated process, often determined by historical access points. And my guess is that it may always be clear where the public right of way is. So if you remove a barrier, you do it at your own risk.
For the most part, that's right. However, the questions then becomes where the points of access are and what are the rules requiring and establishing access. This is something that is likely determined on a state by state basis. I'm not quite sure what the standard is for determining where access points are, where they are required, etc. I wouldn't be surprised if there was some reasonable public access standard, where an access point might be required if the absence of one would unreasonably prohibit access.
Here's a fairly recent map of Southern California access points.
http://www.latimes.com/...ess-g-htmlstory.html
If you look at it, you'll see the access points are generally located where there is private ownership above the mean high tide line.
Yes. For example I believe that all beaches in HI are public
In Cal public access is as noted below mean high tide
Re: Lawyers - how is this possible [Danno] [ In reply to ]
He'll keep on going until he finds somebody who either takes or pony's up the money:
"Khosla’s attorneys, who have argued the case is a violation of his private property rights, are expected to appeal to the state Supreme Court, and eventually perhaps, the U.S. Supreme Court"
Unlimited funds...
He basically wants to force California to buy the property just for the access.
http://www.mercurynews.com/...ic-by-appeals-court/
Re: Lawyers - how is this possible [windschatten] [ In reply to ]
Unlimited funds...
Maybe he needs to recognize that the state has remedies that don't involve monetary compensation.
