kokketiel wrote:
Isn't this picture outdated now that all Shivs are on the low-stack aerobars?
As part of the recall, Specialized swapped out my M frame for a S because I could not get the setback on the new stock aerobars and I was not happy with the aftermarket aerobars the LBS used.
Did Specialized ever publish a new graph?
I don't think they ever updated it, post-bar recall. Subtract 19mm from the stack and the chart still works.
I'm another person who couldn't get the pad setback w/o them using aftermarket bars (Zipp Vuka Alumina in my case). The chart never represented the extreme setback (or forward) you could achieve with the original bars. Theoretically you could put the pads 20+ cm back of the basebar if you slid the extensions back far enough.
ECMGN Therapy Silicon Valley: Depression, Neurocognitive problems, Dementias (Testing and Evaluation), Trauma and PTSD, Traumatic Brain Injury (TBI)
