davros wrote:
WTF does a salt tablet have ostarine in it? A quick google indicates this is some sort of cutting edge PED. It can't be cheap. Its unbelievable to me that it would get in a product by accident.
It's a fairly common, readily available over the counter drug used to treat, among other things, osteoporosis. Apparently it's common enough that it is being produced in large enough quantities that the chances of it contaminating another supplement in the same facility is reasonably good. It's not like you need to go to a shady back alley with a bag full of cash to find it.
As for the facilities themselves being tested, apparently in some cases there aren't any unannounced tests done. If you know someone is coming then you'll probably make sure you pass, who knows what happens in between though.
I'm inclined to believe that none of the girls (Lisa included) knowingly took it. As far as I know it clears the body fairly quickly and won't do much to help you during a race. With that in mind it doesn't make much sense to take it before a race when it won't do much for you and there is a chance you'll be tested.
