Re: Let's see your ride! [Orbilius] [ In reply to ]
Wow, that is nice! I still love my P4 and might start looking for a used Ventus and TriRig brake like you have. I live in a really hilly area so I will stick with my double up front, but again, your setup looks very cool.
Re: Let's see your ride! [DuGuy] [ In reply to ]
2012 P3
Re: Let's see your ride! [DarkSpeedWorks] [ In reply to ]
Hi DSW,
The front wheel is a tubular, originally built for the track. There are still available, because the assembling relay on the made to measure system.
Once you tell your weight, your profile, and what you will do with your wheels, BisonWheels is more able to advise you and give you the best compromise for your request. All the process is 100% artisanal.
You can reach Michal, head of the production, by email. He's fluent in english and is totally agree to send his wheels abroad.
Re: Let's see your ride! [NoLimit] [ In reply to ]
Thanks, but does he have an email ?
Also, do you know if the wheels are available in clincher?
thank you again,
Greg
My speed bunny. First road bike with Aero Bars and Zipp 404s. Currently building a Shiv for my next bike.
Greg,
you can join im by e-mail at : klucha.ms@gmail.com
He also provides a large range of clincher wheels.
NoLimit wrote:
Greg,
thanks for the info !
Re: Let's see your ride! [Sweeney] [ In reply to ]
Just finished putting together my new IA4 and took it out for a spin this morning. My favorite bike by far.
Re: Let's see your ride! [NOLA_TRI] [ In reply to ]
Shiv bladder in the downtube?
Re: Let's see your ride! [frenchieTT] [ In reply to ]
Yeah, I put on a 3D printed cover that fits a shiv bladder
Nice one. Lovely bike.
Re: Let's see your ride! [sooners175] [ In reply to ]
Love it !
I want do do a similar colour scheme but with neon green / lime (team colours) :-)
WD :-)
Nice ride! Wondering where you got the Zipp decals, I want to get a neon yellow set for my 808's. I can only find that color combo for a 404/808 set.
Re: Let's see your ride! [Pennstate506] [ In reply to ]
ebay
So, my new TT Bike is ready.., its Off Season though, but next year will come.
Got it on Sale from my dealer from 2015 and upgraded it now with the fitting wheels. Some adjustments still to make, Need a shorter saddle for sure and the rest will come :-)
My Scott Plasma 5 Team Issue with SRAM Red 10-speed and Zipp 808s. Also, I made a custom mount for the Garmin to get it down and centered.
Orbilius wrote:
My recent "downgrade" from my P5-6. I wasn't doing enough TTs to justify a superbike and long&low just works better for me anyway. From the limited field testing I have done thus far this is faster for me than the P5. Sram force 1x11 setup with a Riken AL. Using my Light-Bicycle 90mm wide clinchers which I have run tubeless with the Vittoria Corsa Speed 23c tires. Sold my disc and will use a wheel cover or team disc for my few TTs a year.
This thing... well done.
Re: Let's see your ride! [AndresLD] [ In reply to ]
Took a while to build this up from the frame set over weekends when balancing twin infants, but got it all settled. Only needed LBS for their crank tool - very happy I took the time to do this myself. Will fine tune the fit (i.e. arm pad angle) over time.
- Felt IA16 Frame
- TriRig AlphaX Bar with Tilt Kit
- TriRig Gamma Extensions
- CeeGees ArmPads
- fi'zi:ik bar tape
- TriRig OmegaX Brakes (front and BB)
- Shimano Dura-Ace Crank with Pioneer Powermeter
- Kogel Ceramic BB Adapter
- Shimano Ultegra Front and Rear Derailleur, Cassette and Chain
- Shimano Dura-Ace TT Shifters
- TRP Brake Levers
- Xlab Torpedo BTA Cage on TrigRig AlphaX BTA Mount
- Xlab Delta 400 with Gorilla Cage behind the saddle
- Quintana Roo QBox modified and re-drilled for good fit on the IA
- Flo Disc and Flo 60 (Flo 90 as well)
Re: Let's see your ride! [NWash] [ In reply to ]
10/10 well done sir
Very well put together sir! Congratulations!
Re: Let's see your ride! [GreatScott] [ In reply to ]
Nice bike ! What BTA system do you use ?
Re: Let's see your ride! [Alex2204] [ In reply to ]
Thanks! Glad to see the thread still lives.
I've been quite satisfied with my BTA mount from Zipp:
http://www.zipp.com/.../detail.php?ID=30010
Scott
Just built up a track bike for pursuits and mass start races. Drop bars aren't in yet, so only have pics of the pursuit setup. Team has a Zipp 900 and 808 track setup to borrow for races. Using the same crank as I have on my TT bike - Quarq riken AL 165mm with a 52T x-sync ring. Just swap them out when I want to ride either bike. Bars were loose when I took the pic - going to level them out. Ordered the Zipp Alumina Evo 110mm extensions for more reach and 15 degrees of rise. Using this stem for drop bars and changing out to an aluminum zipp -17 with the aerobars to dial in the fit.
Looking forward to getting it on the track.
Finally have my own set of race wheels (thanks classifieds). couldn't bring myself to post with just the stock rims.
2019 T-Rex Tri Series
