Re: TRIRIG OMNI IS COMING!!!! [PubliusValerius] [ In reply to ]
I've taken the day off work. Cleared my schedule. Got all of my social media accounts lined up and cash transferred into my bank account. I've declared next Tuesday, Sep. 13th
OMNI DAY
Hope I'm not disappointed.
Re: TRIRIG OMNI IS COMING!!!! [nickwhite] [ In reply to ]
I hope it is a new frame that will integrate all of Nick's products and that he takes the next step with his products and in the process shows the big manufacturers how to do things better.
Re: TRIRIG OMNI IS COMING!!!! [BMANX] [ In reply to ]
I hope so too. It would be sweet to see him go toe to toe with the big guys.
Re: TRIRIG OMNI IS COMING!!!! [kgro] [ In reply to ]
kgro wrote:
a lot of things will be released before the new Cervelo
Trump's tax returns
Re: TRIRIG OMNI IS COMING!!!! [refthimos] [ In reply to ]
Trump will be president before Cervelo release anything new.
The Sagrada Familia will be completed
And another shot
Re: TRIRIG OMNI IS COMING!!!! [Nazgul350r] [ In reply to ]
After looking and looking and looking... I've got nothing haha
It is not too surprising that cranks create that much of a drag-hot-spot since there is clearly no rider on the bike. I imagine the crank doesn't stand out that much as an issue when you combine the rider+bike since it becomes effectively merged with the leg (which obviously does create a huge amount of drag), and during large portions of the pedal stroke it is hidden from the wind by the lower leg and foot to a large degree.
Could it be a(n) (aero) crank, that fits all the different bottom brackets? Would fit the name Omni..
Re: TRIRIG OMNI IS COMING!!!! [SkippiTT] [ In reply to ]
That picture is not a crank.
Re: TRIRIG OMNI IS COMING!!!! [BryanD] [ In reply to ]
Part of it could be.
There is an x,y,z origin sitting there in the crank. Not sure if it means anything.
If the last image means anything, it could be a bike for the Predator.
Maybe but I'm not inclined to believe that Nick would stock three SKUs (165mm, 170mm, 175mm) and there's no way he's embedding a power meter in the crank or spider (which many triathletes already have and would be reticent to give up). To me that looks like a 175mm Vision Metron on a relatively small frame.
Re: TRIRIG OMNI IS COMING!!!! [GreenPlease] [ In reply to ]
Agreed. Plus the two previous teaser pics did not even show the BB area of a bike.
Re: TRIRIG OMNI IS COMING!!!! [Ellsworth53T] [ In reply to ]
I would probably say that it means that the bottom bracket is frequently taken as the origin for bike coordinates...?
tweets.
Re: TRIRIG OMNI IS COMING!!!! [siegfried08] [ In reply to ]
Probably.
I don't think the omni is a crank either, I was just pointing out that in that drag (?) heat-map, the crank was the obvious hotspot. Perhaps it will just be a front skewer/hub instead ;)
Re: TRIRIG OMNI IS COMING!!!! [BudhaSlug] [ In reply to ]
Just as a clarification.....on Facebook Nick mentioned this was a velocity heat graph. That is different than a drag heat map. The 2 things are obviously related, but the correlation isn't always so obvious.
... With that heat map around the bottom bracket area.... how about a low profile bike motor ?
I didn't know Andy Coggan's janky AF low speed wind tunnel was capable of outputting such heat maps.
Of course it can... just put a small but powerful computer inside that little wind tunnel and run your CFD aerodynamic modelling on it. Miniature wind tunnels make great computer storage spots... plenty of cooling.
My prediction: it's a bike.
Tririg actually confirmed on Facebook it was a bike!
Edit: And they deleted their comment on fb.
we live in strange times where narrative has way more impact than utility or truth...
-SteveMc
Re: TRIRIG OMNI IS COMING!!!! [pirate_rrob] [ In reply to ]
I saw that too.
