DIY disc wheel - monokote heat shrink film
I thought I'd post this in case anyone wants to try this. I read about this in another DIY disc wheel thread, but did not find any detailed instructions or videos on the interwebs on how to do this.
wheel: chinese zipp 303 knock off carbon tubulars, very lightweight, has straight (and non dimpled) rim profile good for gluing the monokote to
materials:
top flite monokote film 2'x6' - $20
superglue acrylic contact cement - $8
yoghurt lids or other scrap plastic - free
tools
sealing iron - $40 (you can get a cheaper one)
heat gun (i just used my regular home remodel one I have, worked fine)
compass
felt tip pen
exacto knife - $11
scissors
scrap piece of foam or brush (to spread the contact cement on the rim)
DIY level: intermediate.
time to complete: 3hrs
I cut 3 circles out of various scrap plastic (yoghurt lid or similar) for the hubs and the valve hole. I attached the ones for the hubs using tiny scraps of duct tape rolled with the sticky side out.
the monokote film is very lightweight, its 24" wide and 6' long and a single roll will cover 1 wheel with plenty of extra for experimenting. i chose matte black, but its actually a dark grey color, just like in the picture.
I did the more dished, non drive first, and then the drive side. I decided to have the valve hole on the drive side because the valve is closer to that side. I marked the valve location on the tire with the sharpie (yes, its where the tire decals are, but just to be exact). I iron sealed the film over the yoghurt circle around the hub first (did not use any glue there) and then used the contact cement around the rim and glued the outer edge down. This is what it looks like before you shrink it with the heat gun.
I shrunk it to a tight drum like finish with the heat gun, this takes quite a bit of time and practice. It seems the film first stretches when you start heating it, and then if it reaches a certain temp and then cools then it shrinks. It took me quite a while to figure out the correct temp and time to get all the wrinkles out, and managed to only burn one hole in it on the first side I did. Once it cooled, i cut out the valve hole and glued another yoghurt circle plastic from the inside to enforce the valve hole on the drive side.
the non-drive side. I did this one first, i patched a small hole I burnt near the rim.
The final product:
Two wheels good. Four wheels bad.
Re: DIY disc wheel - monokote heat shrink film [DrTriKat] [ In reply to ]
Have you ridden on it yet? I imagine it's structurally sound because it's still a whole wheel underneath, but does the cover flutter or get sliced by road debris? Would it not be easier and almost as inexpensive to mount a disc cover, especially since you could remove the cover?
Register for Tri the Illini! Urbana-Champaign's premier sprint triathlon! Register here: http://www.fightingillinitriathlon.com/index.html
Re: DIY disc wheel - monokote heat shrink film [Red X] [ In reply to ]
I have not ridden on it yet. I found a guy on the interwebs who did this to a track wheel on his fixie commuter bike that he has been riding for months (?years I can't remember) without any problem). The finish is like a tight drum, I would not expect it to "flutter" in the wind (i'll cover the valve hole with tape).
It weighs essentially nothing. The wheelcovers weigh a ton. They are also not that quick to remove/install as you still have to remove the cassette, line them up, tape them to the spoke, make sure they are not warped, electrical tape around the rim, etc. But mostly, I just didn't like how much weight they added. I weigh <130lbs and the weight of the wheels count for me (also most of the races I do have some climbs/hills).
Pretty cool. How much weight did it add? Seems like a decent option for a hilly course or an already lightweight rider. I think a wheelcover normally runs you 400 grams or so. It seems like it would ride like Gerlachs packing tape which he used in races. Keep us updated.
Re: DIY disc wheel - monokote heat shrink film [adambeston] [ In reply to ]
see my answer above.
The monokote film adds essentially no weight. Its very important here because we have hills/climbs and I am a lightweight rider and not very powerful (yet, I am working on it!).
I guess my fluttering question was more about air getting in the valve hole, but if that's covered then it wouldn't be a problem. I'm not saying the cover would be easy to remove and put back on; only that you'd have the option. I suppose it wouldn't matter if the DIY wheel was a committed race wheel. Does the cover stretch at all if poked or is it pretty strong? That is to say, can you confidently pack it or put it on a rack without worrying about the cover stretching and becoming loose?
Post deleted by Administrator [ In reply to ]
Good job, but you need to work on your Googly skills!
From 2003: http://lists.topica.com/...rt=d&start=14068
Slowtwitch (with a reference to the above): http://forum.slowtwitch.com/...ing=ultracote;#72883
Why I know a bit about this (probably my third iteration, built on an AC350 wheel):
(photo not loading right now, alas)
"Go yell at an M&M"
It is a dedicated race wheel. Even when I had the aerojackets on, I essentially never removed them because it was such a pain in the a**. I put my bike on the rack with the training back wheel on because the rack holds the bike by the wheels, and always carry my back race wheel in a case inside the car.
All my races are on courses with laps around, so even if its windy, that's only a portion of the course that I'd have a cross wind. So I don't really plan to remove them at all.
I had removed the aerojackets once for a race because there was a lot of climbing and the weight was an issue.
You can drum on it its so tight. I'll post an update once I ride it, I can even mount my camera to video tape it while riding to see if there is any rippling or such.
I tip my hat to you, Doctor. Well done!
Did you happen to figure out what setting is needed to initiate the sealing? Also, how did you determine the right diameter for the circle to be cut out?
Re: DIY disc wheel - monokote heat shrink film [gabbiev] [ In reply to ]
Thanks for sharing! That's great.
Are speedos required when racing with a shrink wrap disc wheel? :-)
Re: DIY disc wheel - monokote heat shrink film [echappist] [ In reply to ]
I first cut a 24"x24" square, marked the center, then cut out the center hole for the axel. Then put it over the hole, and marked with a sharpie going around the perimeter in the groove between the tire and the rim - this made it circular but still larger than needed. Then I removed the film, removed its backing, then sealed it around the hub/axel portion first, and then folded it up over itself out of the way into the center of the wheel and applied the glue (cement) to the rim, then glued the edges to the rim, then went around the rim with the exacto knife and cut off the excess that was just loose over the breaking surface. I used the sealing iron around 200C. I used my regular heat gun on its highest temp setting with the low blow power for the shrinking.
Looks very cool. Nice job.
However, you may want to read up on weight savings and their impact. You seem to be putting a lot of emphasis on weight reduction for your reason for going this route. I think that if you may find that it isn't really helping you like you think it is. The example cited below shows what a 3.2 lb weight difference makes...a 400g aerojacket cover is .88 lbs
http://www.usatriathlon.org/...e-weight-102113.aspx
Re: DIY disc wheel - monokote heat shrink film [Twotter] [ In reply to ]
You cannot measure the psychological factor of the feeling of lightness.
How much did the rider weigh in that experiment you are quoting? Weight may matter, because even though a smaller rider is dragging less total weight uphill, a larger % of that weight is the dead weight of the bike, and if the smaller rider is female, than the relative power to drag that weight up diminishes, and I would wager that for a much smaller and less powerful rider, the weight savings may be more significant (not to mention that given the cost of materials of <$30 for a membrane disc, the cost/time is awesome compared to a conventional disc wheel). If anyone wants to crunch numbers, I currently weigh 127 lbs, and my 20 min FTP is 136W.
From analyticycling.com:
Weight w/bike: 66kg
Slope: 7% (Old La Honda grade)
Power: 136W
How much less weight: .4kg
Distance: 3000m (about how far you'd go in 20min on this grade)
Time savings: 6.11 seconds
Yes, that's all.
"Go yell at an M&M"
http://analyticcycling.com/ForcesSpeed_Page.html
At 6% grade, your weight and power, and 17.5lb bike, 400g makes a .02 m/s difference, yielding a 72m difference over a hour, or 0.63% of distance traveled. It's about about a watt difference. Not insignificant but not that great.
I'd also venture that you can get a CF cover like the Catalyst, which is an order of magnitude more expensive, but only 50g heavier and most likely significantly more durable (and it shimmers.).
Very curious how the MonoKote holds up to impact from rocks though, seems like it's asking to get torn, and it doesn't look like an easy on-the-road repair.
Re: DIY disc wheel - monokote heat shrink film [klehner] [ In reply to ]
Weight w/bike: 66kg
Power: 136W
Yes, that's all.
Considering that the net benefit of a disc on the same order of magnitude, I'm not sure "Yes, that's all" is called for. ;)
Re: DIY disc wheel - monokote heat shrink film [aravilare] [ In reply to ]
aravilare wrote:
Weight w/bike: 66kg
Power: 136W
Yes, that's all.
The point was that doing this versus the wheel cover just doesn't save that much time. 6 seconds isn't that much time.
"Go yell at an M&M"
Thanks for that. The CF covers seem great, but I can't at this time justify purchasing a wheelcover that costs more than the wheel you put it on. Just seems silly. But I can probably add some glitter to make mine shimmer as well!
Might this also work better for bikes that have cover fitment issues?
klehner wrote:
aravilare wrote:
Weight w/bike: 66kg
Power: 136W
Yes, that's all.
And my point was that the net benefit of this is very close to what you're saving by putting a wheel cover on the first place versus a deep rear wheel on a standard course.
Assuming:
1km climb at 5% grade
Rider+bike with disc cover= 66.7kg, CdA=.235, 200W power output
Rider+bike with/out disc cover=66.3kg, CdA=.250, 200W power output
Otherwise the conditions/riders/efficiencies are the same.
Over the 1km climb at 5% grade the 2 riders tie.
On a flat 40k course with 120W output the disc wins by ~1:26.
Even at your weight and power output you're pretty much never going to lose on the disc cover weight vs. aero, and it sounds like your ultra-light version is a best-of-both-worlds solution anyway. Good work!
__________________________
I tweet!
Re: DIY disc wheel - monokote heat shrink film [owen.] [ In reply to ]
That was one of the reasons I did it. I was not happy with the fit of my cover, it had rubbing issues due to the fit (the dishing and diameters are not quite the proper fit for my wheel) and thickness of it.
Nice work. As someone who also builds and flies RC planes, I may have to try this.
Just bought an aerojacket but the fit is terrible and has so far been $100 down the drain.
Hi DTK, thanks for your informative post. I've started the wheel film process similar to the
method you used.
A few questions, if I may:
From what you have learned riding the disc, is there anything you would suggest for the
initial process?
Did the glue joint at the rim hold up? As I'm filming aluminum rims, have been experimenting
with different gluing methods and heavy duty adhesives, sprays, double sided tapes, etc.
Has there been any problems due to high and low outside temperatures, as delamination,
film sagging, and access to the air valve?
I cut my film circles and used some heavy duty spray adhesive on the rim and back side of the
film and heated the joint. The blue tape is pulling a film scrap on the angle to the hub. On disc
brake rims, I'll apply only to the brake surface.
Among out group there's a great deal of interest in repeating your method. I plan to make film
kits so my riders can easily repeat the process. Using the lightest aluminum shallow profile rims,
these filmed wheels will be great for climbing and fast on the flat.
Thanks again for getting the wheel rolling and am lookin forward to your riding experience and
thoughts.
Bill
