cmeeks wrote:
agreif wrote:
I have also tried a couple times to run a workout without opening the Wahooligan app and in both cases I experienced problems. My routine is to open it before I start, establish the green dot, and then close it.
P.S. Why would you set TR to display power from the Kickr at all? I don't really care what the Kickr 'thinks' it's doing.
Just a thought, I always leave my KICKR plugged in and never touch the Wahooligan App on the phone, sometimes I dont even have it with me and the KICKR is connected to my Vectors. Now I went and did the same for my Father (He doesn't have the app) so I brought my phone over to his house and installed the beta firmware on the KICKR and told his KICKR to read my fathers Vector's. It worked for that one workout, now he unplugs his KICKR after he uses it and the next 2 rides his KICKR did not read his vectors and his KICKR was always about 15 watts higher then his vectors.
I wonder if by disconnecting power to the KICKR it is resetting the external PM ID and but opening the Wahooligan app it resyncs the external PM ID which is why some of you are seeing issues when not using the APP? Can you guys try leaving your KICKR powered on and see between rides if you need the app or not.
I'll let you guys know how my father makes out leaving his powered on. It would be damn nice if Wahoo could take the 2 damn seconds to answer these questions for us.
Cheers
Jeff
