Was just wondering if you knew when the 2015 Shiv design and colours would be released?
From memory it is usually around September | October but just thought I would ask.
Thanks.
This is a very strange coincidence as I just searched for a shiv forum to ask about the same issue with the seatpost not moving. My Shiv Expert is only a couple of months old and was set up in a Specialized shop. They did a great job setting it up with the measurements but the other day I decided to raise my seat slightly and couldn’t budge it an inch. I managed to push it in further (in trying to get some movement in it) but regardless of what I’ve tried it will not move at all.
When I had a closer look at the assembly manual http://service.specialized.com/...nstruction-Guide.pdf
; page 20) it states that a "shim and top cap" should be installed at the front of the post, as well as the collar at the back.
On my Shiv there is no shim or topcap (only the collar at the back) and it looks like its the front of the post where the jam is occurring. Hopefully you can see from the pic that the symbol paint has been rubbed off where the post has met the frame where the shim should be. Does anyone else have this fitted on their Shiv?
Here is the link to some pics I put in another forum about this: http://www.bikeradar.com/...2973500&start=20
Perhaps I've got this all wrong, but i'm thinking it has been set up properly at the store. I'm taking it in this weekend so will find out.
Cheers
