Couple of general points here, and this is all old info, but I think that it is worth pointing out again. Is Weiss being tested? I don’t know, but probably. I mention him out because you brought him up. It’s difficult to know just who is being tested, etc. For instance, do you get tested or file whereabouts? Dan pointed this out in his long pieces on anti-doping.
Here is the USADA list, updated quarterly. Granted, he’s not a USA athlete.
http://www.usada.org/testing/results/athlete-test-history/
You can clearly see who is tested, how many times, updated quarterly. It usually takes about a month or so after the quarter ends for them to update. I file whereabouts. I have not been OOC tested this year. I don’t show up on the list above. Other US athletes file whereabouts, but do not show up. So, you can’t definitively say which US athletes are and aren’t subject to filing whereabouts based on this list of tests. But, you can clearly see which US athletes are tested and how often. It does not say if these tests are in or out of comp though.
Here is the WTC page on results management as well as the registered testing pool page.
http://www.ironman.com/triathlon/organizations/anti-doping/results-management.aspx#axzz36eRYfYRg
http://www.ironman.com/triathlon/organizations/anti-doping/testing/registered-testing-pool.aspx#axzz36eRYfYRg
You can see who, according to WTC, is subject to filing whereabouts and therefore, out of comp testing. But, it’s a tricky issue. Great Britain, for example, pulled any long course athlete that used to be in their system from filing whereabouts and being subjected to testing under the British tri federation. So now, that responsibility falls wholly on WTC for athletes like Tim Don, Rachel Joyce, Jodie, Leanda, etc. I name those folks because I am 99% sure that in the past they were subject to testing from British tri.
Blah, blah, blah, it’s tough to know just who’s tested, how much, etc. WTC does do quite a bit of testing, that’s been stated and pretty well verified. What isn’t really verified, has been asked, is who is tested, full results disclosure, etc. The WADA 2012 report lists a summary of all of the WTC, ITU testing as well as a few others I believe. A quick Triathlon summary, you could probably break it down further into ITU/WTC as well as a couple of other types of testing. Total samples in-comp 2054 Urine with 20 AAFs and 19 ATFs. Total sample out-of-comp 1541 Urine with 2 AAFs and 14 ATFs. Total in and out of comp blood 101 and 344, respectively with no AAFs nor ATFs. AAF = adverse analytical findings, ATF = atypical findings. But, neither are necessarily sanctionable. And, you can further get to some of the individual NADOs, etc. but that would take some time. You can’t find the individual athlete on those reports.
http://www.wada-ama.org/en/resources/publications/annual-report/
http://www.wada-ama.org/Documents/Resources/Publications/Annual_Report/WADA-AR-2012-Web-EN.pdf
Again, a lot of this was covered by Dan in past articles. But, it ends up getting lost a bit because attention spans or short or until the next questionable athlete ends up on the podium.
