mrtopher1980 wrote:
astig wrote:
do you have power smoothing setup the same on both the 910 and TR? Can you post links to the garmin file and TR workout?
I didn't see anything about smoothing in the 910. I believe it was off or lowest setting if there is no off in tr. I was able to hold constant power and that wouldn't bring them closer.
And no don't have files, I set it up just to tests last night but have a knee injury so I wasn't doing a real workout. I was going to just experiment and do a free ride 30 but when I saw how far off they were I got distracted and never started either.
With mothers day I probably won't be touching it again until Sunday night to actually save a workout.
edit.. checked TR before I ran out the door and it says smoothing is off, the 910 was showing display block "power" from what I can tell smoothing would be the 3,5,10 whatever second average ones.
Ok, I just posted on the TR thread but now that I've read this more I think you've troubleshooted this as far as you can. Good deductive reasoning on your part, looks like you hit everything I've thought of.
E-mail me at nate@trainerroad.com. I'll send you the official ANT display simulator that you can pair your P2M with. It's a windows desktop app that connects with an ANT stick and will read in power data. You can then pair it with the Garmin at the same time. As long as you're sure power smoothing is off, then you'll know that your 910xt is having problems.
I'd then check for a firmware update on your 910xt, if that doesn't do it I would contact Garmin Support and try to get another.
CEO at TrainerRoad Co-host of the Ask a Cycling Coach Podcast
