Re: Official Specialized Shiv Thread [MattyElmore] [ In reply to ]
Thank you sir. Appreciate the quick response!
Does the 2014 have an adaptor to mount the Magura brakes?
Re: Official Specialized Shiv Thread [Gjadams] [ In reply to ]
The 2014 Pro and S-Works come with Magura brakes stock. (The Pro frameset does not. It comes with stock brakes.)
The adapters are available through our service center. They're in stock right now as well.
Mark
Mark Cote
MITAerobike
Specialized Bicycle Components
Re: Official Specialized Shiv Thread [MITaerobike] [ In reply to ]
Will the adapters fit on the 2012?
Yup, made to fit all carbon Shivs. Doesn't easily play well with Shiv TT, but can work if someone wants to drill out the stem.
Mark
Mark Cote
MITAerobike
Re: Official Specialized Shiv Thread [Tell3131] [ In reply to ]
Couldn't agree more. Is there any work round to create the dual shifter set-up?
Mike
Re: Official Specialized Shiv Thread [MCSLC] [ In reply to ]
Are any special parts needed to mount the aerobars under the base bar like shown here? I think to get my stack height where I want it, with proper reach a size small TT module, with the bars mounted under, and the forearm pads mounted directly to the top of the base bar. That seems to be what has been done here.
The shiv pro race is shown with magura brakes on the specialized website?
Mark
Re: Official Specialized Shiv Thread [Professor Chaos] [ In reply to ]
Those aren't the Shiv bars. Those are Pro Missile Evo bars.
Have you tested the best type of disc wheel for the Shiv's yet? (flat vs lenticular disc)
Re: Official Specialized Shiv Thread [Philosoraptor] [ In reply to ]
I see thanks for pointing that out.
2 years no flats. I mistakenly used the rear one on the trainer the other day, ate it up a bit, so I am thinking to replace it before going to IM in December.
But yea, solid stuff.
Swim with swimmers, bike with cyclists, run with runners. Train with those who are hard to keep up with. Soon you will be hard to keep up with.
Re: Official Specialized Shiv Thread [tomaco1] [ In reply to ]
Re: Official Specialized Shiv Thread [Tony5] [ In reply to ]
Hey Tony5,
At 0, a flat wheel is slightly better than lenticular. But at YAW the lenticular performs better with the bike.
I'll look around for something to put up here.
Matt Elmore
Product Marketing
Tks
Hi all - first post on here....been a lurker for years.....
A question the Specialized to the tech heads. I have Shiv TT that I need help sorting.
I was hoping to draw on your experience with the design of the Shiv TT and help solve a problem that I am having trouble overcoming.
It’s to do with the aerobar arm extensions. Simply put I’m finding that the arm extensions are moving on the supports when I’m riding and also these can moved with minimal pressure when back in the workshop. I can confirm that I have followed the instructions as directed and all screws etc and been tightened up to the recommended torque settings.
I have worked with the bike shop and sadly no solution has been found. We’ve even done a complete swap out with a completely new set of aerobars etc.…..sadly it hasn’t solved it.
Obviously finding this a tad frustrating – especially on the bike. I realise that the frameset aerobar options are limited here – it looks like the only other rider out there with difference front end set up is Tony Martin – but I suspect he’s had a custom built stem.
Can you help - many thanks in advance.
Andrew
Hey all,
The Magura Adapters are split into front, rear, and bolts. You need all three to mount a complete set. The front and rear adapters ARE different as they cant the brakes a bit differently to clear the chain off of the chainstays in the rear.
S140500008
BLT MY14 SHIV MAGURA BOLTS FOR BRAKE ADAPTERS (SET OF 4)
S140700010
BRK MY14 SHIV MAGURA FRONT BRAKE ADAPTER (WITHOUT BOLTS)
S140700011
BRK MY14 SHIV MAGURA REAR BRAKE ADAPTERS (WITHOUT BOLTS)
These numbers can be given to your retailer to order!
Mark
Mark Cote
MITAerobike
Re: Official Specialized Shiv Thread [AGSUB20] [ In reply to ]
Andrew
This is pretty specific to how your bars are setup on your Shiv TT. I believe we're emailing back and forth now - let's stay in touch that way and we'll get it all solved for you.
Mark
Mark Cote
MITAerobike
Matt - are these for carbon or alloy bars - or both? I'm thinking a trip to my LBS is in the very near future.
Quote:
S140800002
BAR MY11-14 SHIV LOW STACK AEROBAR CLAMP LEFT
S140800003
BAR MY11-14 SHIV LOW STACK AEROBAR CLAMP RIGHT
My shiv is going to be Rockin with an even more slammed setup & the Fuelcell.
Thanks,
James
Thoughts on being an Urban Triathlete
I did Augusta over the weekend with my new Fuel Cell. Gotta say I loved it! It's easy to reach down while in aero and pull out a gel, while keeping your eyes on the road and other riders. The cycling gods allowed my tires to make it through 56 miles unscathed so I didn't have to dig deeper into the Fuel Cell. Although pulling stuff out of the Fuel Cell is a hell of a lot easier than getting it in ;)
Kudos to Specialized on a good product... IMO. Now a how about a white version? :P
Thanks for the info. Do you happen to have the torque specs and loctite to use for these bolts?
Re: Official Specialized Shiv Thread [urbantriathlete] [ In reply to ]
Yoo,
Those will work on either Aluminum or Carbon bars, i'll double check to be sure though.
-Matt
In regards to the clamp on the left (from the riders perspective), is that the lowest it can go? Or are there still a few spacers under the clamp? I'm assuming this clamp works on the alloy version also? How much lower will I get by using this clamp than the stock one that has the angle adjustment?
This is the part number correct ?
S140800002
Any idea on pricing for the clamp?
Re: Official Specialized Shiv Thread [hayai_240] [ In reply to ]
S140800002
19mm lower stack compared to the stock adjustable clamp. yes, this works on the alloy and carbon Shiv bars (not Shiv TT). The spacer system still works underneath this. Not sure on cost as this is a service part. Your retailer should be able to answer this.
Mark
Mark Cote
MITAerobike
Thanks for the quick response. Just to double check before placing an order, the part # is S140800002 correct?
