berkeley wrote:
Dave, is the frame compatible with internal batteries for di 2 & eps?For Di2 yes, there is a special carrier mounted to the InternaLoc seatpost binder that captures the Di2 battery and allows it to use a fixed cable length so saddle height adjustments are not tethered to the e-tube wire. For EPS, the internal power unit was designed around a 27.2mm round post. It will fit in the seat tube of the 54 thru 61cm sizes but not the 48 and 51cm. The two smaller sizes need to have the PU o-ringed with foam insulation and dropped thru the head tube into the downtube. The charging port is capped with a small hole under the BB shell.
Campagnolo has yet to make production Power Units available so we'll use the external PU for the AR3 EPS and mount it under the downtube just in front of the BB and somewhat sheltered by the crankset.
-SD
https://www.kickstarter.com/...bike-for-the-new-era
