Just got the disc.. I see the crack pipe but how the hell do you use it with the small valve extender? It seems they do not interlock in any way.. do I just hold the adapter next to the valve and then pump.. wouldn't air escape?
Re: Pumping up a zipp super9 [125mph]
Hold it on the valve stem with one hand so that the air doesn't blow the Crack Pipe off. Pump with the other hand. Put your back into it.
The Zipp Crack Pipe connects to the Schrader side of your pump head if I'm not mistaken, but obviously works with Presta on the business end.
Re: Pumping up a zipp super9 [SWoo]
If you don't have any friends, a high pressure 12v compressor allows using the crack pipe by yourself.
something like -
http://www.sears.com/...sName=Inflatorsmv=rr
Tha battery powered versions are more portable, but a CO2 cartridge is still needed for on the road inflation.
something like -
Re: Pumping up a zipp super9 [Jamaican]
Jamaican wrote:
Hold it on the valve stem with one hand so that the air doesn't blow the Crack Pipe off. Pump with the other hand. Put your back into it. The Zipp Crack Pipe connects to the Schrader side of your pump head if I'm not mistaken, but obviously works with Presta on the business end.
Great. I used the zipp crack pipe and was able to pump up the tire.. However. its hard as hell to tell how much PSI is in the tire because so much air is leaking out while I'm pumping.. How does everyone get around this?
I was having the same issue with the Zipp crack pipe. I went back to the older style and was able to get a better gauge of the air pressure.
This is the same one I use and it works better than the zipp.
http://www.acmebicycleco.com/...l-inflation-adapter/
1) Attach the Crack Pipe to your pump head.
2) Screw down the head of the Crack Pipe until it's nice & tight. That way it will provide a good seal once you slide it on the valve stem.
3) Now align the valve stem in the 12:00 position.
4) Attach the Crack Pipe to the valve stem. Your palm should be on the top of the tire, while your fingers hold the head of the Crack Pipe securely on the valve stem.
5) When you pump (with the other hand), no air should escape. Pump to the required PSI.
6) When you're done, just let go of the Crack Pipe & it will fly off, then tighten the valve stem.
I'm half tempted to make a youtube vid ....
I'm using the zipp valve extender. I think that's why it isn't as easy. I will try without valve extender!
You need a valve extender for a Zipp disc? I don't know much about them, but isn't the cut-out shallow enough to use a regular tube, say 36mm stem?
I run a Super 9 on my TT bike and there is no need for a valve extender - in fact, I'm not sure one would fit even if you tried to use one. There is just enough room to get the crack pipe on a short (eg 36mm) valve stem and not a lot more. Honestly not sure how you could fit a valve stem in the cutout, and even if you did, the extender would end more or less at the top of the cutout, and you couldn't fit a crack pipe or anything else in there.
