Lose weight, save how much time in 5K
I have seen various figures thrown around and while I know it varies from person to person, what on average would you say would be time saved in a 5K vs. lbs lost.
If I was to guess for myself, at 180 lbs or so, if I lost 10 pounds and still kept my strength and endurance, it would maybe equate to 45 seconds?????? this is a total guess. Thoughts? Studies would be great if you can show me a link to them.
Jeff
Just found this...not sure how legit it is.In terms of running, smaller is usually better. Packing extra body fat on your frame will slow you down. In his book, “Serious Runner’s Handbook”, running expert Tom Osler suggests that every pound of excess weight will decrease your running performance by 2 seconds per mile. So, if you add 10 pounds of unwanted body fat you will lose 20 seconds per mile from your running pace. There is little scientific evidence to back up that claim, but in both my personal and coaching experience I have found that number to be fairly accurate. Of course, that will vary from person to person, but there is no question that excess body fat weight will slow you down.
Re: Lose weight, save how much time in 5K [Jeff Spicoli] [ In reply to ]
Jeff
Apocryphal lore is 2-5 seconds per lb lost per mile. Depends on some factors like efficiency, where you are on the whole scale of things, etc. 2 seconds is probably a good estimate, so for 10 lbs 45 seconds to a minute is probably a safe guess.
John
Top notch coaching: Francois and Accelerate3 | Follow on Twitter: LifetimeAthlete |
In general of course, lighter is better for running. But that would be a nightmare of a thing to try and test reliably, with all the variables involved... weight vs pace (which pace, threshold? vo2max?). Also need to account for fitness, body fat % (weight doesnt necessarily mean good composition), recent nutrition (hydration & glycogen levels, caffeine etc), recent training (rest, taper), temperature & conditions on the day, etc.
I have read for years about 2 seconds per mile pace per lb. I lost about 15 lbs, and was close to this. There is nothing negative about losing weight, unless one over does it.
Dave Campbell | Facebook | @DaveECampbell | h2ofun@h2ofun.net
Boom Nutrition code 19F4Y3 $5 off 24 pack box | Bionic Runner | PowerCranks | Velotron | Spruzzamist
Lions don't lose sleep worrying about the sheep
If you were to train more (say running) and lost 10 lbs through that, and say you trimmed 45 seconds per mile, there is no way to determine (outside of a controlled experiment) if the speed gain was from the 10 lbs lost, or the increase in running/training volume that lead to the weight loss. Maybe you just got faster because you ran a hell of a lot more. Or maybe it was from the decreased weight, or likely from both.
Anyway, I think it's pretty obvious someone not carrying extra weight will be faster (assuming they are fit). And I have also heard 2-5 seconds per mile per lb lost.
Good luck, I'm sure whatever the speed gain, you'll be faster with a little weight trimmed off. Report back after you've done it.
Empire Tri Coach
Team Gatorade Endurance
USATF Coach | NYRR Distance Pacer
Dad of twins
Re: Lose weight, save how much time in 5K [Mendeldave] [ In reply to ]
No, you probably can't differentiate between whether it's weight, efficiency, extra training, etc. But even if you don't understand the left side of the equation, the right side still comes out around 2-5 seconds/mile/lb from all the N=x that I've seen.
And I agree, it's most likely a multitude of different things adding up the create the increase.
John
Went through this last year,
Started out at 185 lbs in early summer, got down to 151 by around christmas. This was kind of my "fat to fit" stage as I was out of the sport for 4 years.
5lbs = 30 seconds per 5km, for me - every ones different.
If you're really bored you can read about it on my blog (mo diet weeks 1-9)
Cheers,
Maurice
I can give you the reverse. I'm as equally trained this year as last year but I'm about 10 lbs heavier. On the same courses I ran a 5K 40 seconds slower and half-marathon about 7 minutes slower.
Here's my math:
Age 18, weight 145, 35-40 mpw (running only) 5k PR 16:15 (sea level)
Age 41, weight 180, 15 mpw runnning (cycling and strength training), 5k PR 20:55 (5500ft)
Lots of variables I know but the 2 seconds per lb, per mile is pretty close.
Formerly DrD
I lost about 10lbs over the winter this year thinking I would get faster. I didn't.. I think I ended up losing too much strength in the process and didn't have enough energy. My bike times got worse as well..
Started focusing more on proper nutrition rather than weight.. put on a few more pounds and got faster. So I do think losing weight can have a negative impact
Team Every Man Jack
Jack Daniels says 1-2sec per pound
Eric - "Train Smart, Race Smart, Finish Strong"
Re: Lose weight, save how much time in 5K [ejchet] [ In reply to ]
Jack talks to me sometimes too.....oh, I think we are talking about different jacks here
Tim
Tim
Re: Lose weight, save how much time in 5K [rj_tri] [ In reply to ]
You make a good point. Proper nutrition during weight loss is key. If you lose weight by simply running a calorie deficit, you run the risk of cannibalizing your muscle instead of fat (by not taking in the right nutrition AT THE RIGHT TIME ie protein during a long workout and after a hard workout).
I've done this before - I lost 10 lbs over the winter and despite a hard winter cycling schedule I lost 10+% off my bike FTP. The problem was that I was so worried about the calories that I didnt eat after working out. Big mistake.
However, you can still run a calorie deficit and continue to improve fitness and performance. More recently, I am down another 10 lbs and done so with running a calorie deficit. However, after a workout I take in a lot of protein right afterward. My run times are improving, but as a measurable benchmark, by bike power numbers across the spectrum are up about 5% over 4 months.
Here's a reasonably good article on guidelines for what you should eat and when:
http://www.bikeradar.com/...eed-and-power-24762/
Bottom line, if you do it right, you'll get faster while you lose weight
- Pete
Luckily my over eating disorder is offset by my over exercising disorder
Oh, absolutely true. Periodic testing should be part of the arsenal of every athlete, so you can detect/avoid the downside.
John
Too may variables with losing the 10 lbs... and why struggle? Take 2 ounces off each foot (maybe a useless toe) and be 15 seconds faster per mile overnight!
For me this is the closest estimate to what I find.
Since I did my Ironman I've put on 7lbs and have found that I run my favourite 10 mile tempo run Approx 15 seconds per mile slower (7min/mile) at the same HR than I did pre Iron man (6:45min/mile). Obviously there are a number of variables at play but if you work off 2-3sec/mile per lbs I doubt you'll be far off.
I think if you wentnon one of those designer diets for a few months you would be really fast. Say............ A gluten free diet :0)
Official Polar Ambassador
http://www.google.com/...P7RiWyEVwpunlsc2JtQQ
Re: Lose weight, save how much time in 5K [Pedalhead] [ In reply to ]
I've seen the light shoe thing being thrown around a bunch and don't buy it for a second (excuse the pun). Sure, a set of 12 ounce trainers will be different than some 7 ounce flats, but within reason.. I don't believe it. 9ounce vs. 7 ounce shoe, no way there's a 15sec/mile difference. Or even a 5sec/mile difference.
Re: Lose weight, save how much time in 5K [phoenixR34] [ In reply to ]
Hmmm, I wonder why middle-distance runners wear very light flats or spikes? Research on shoe weight and the energy cost of running provides indisputable evidence of the higher efficiency of running with light shoes. Over the marathon distance, a 2oz lighter shoe equates to the energy cost for running one mile. That saving of energy should translate into a faster time.
Yeah, same reason triathletes use aero water bottles.
There is a big difference between racing flats and trainers. I run in a trainer that is about 8 ounces and in a racer that is about 5 ounces. I run about 5 -10 sec per kilometer faster in my racers. However this may be a placebo effect.
https://www.devinwittig.wordpress.com , https://twitter.com/DevinWittig -Xterra Wetsuits (Pro deal code SA-WITTIG) Rudy Project - Sketchers Performance - Rocktape Canada
How about: go run a mile at 5K pace. The next day (or when recovered) put on a 10 pound weight belt and run the same mile at the same effort and HR. Subtract 3.1 times the difference. Should be in the ballpark; better than a total guess, anyway....
Brilliant
It is possible to calculate an estimate.
Your fitness level can be estimated by a cooper test.
The number you get has the value (mmol O2 )/ kg
180 lbs ~ 90 kg.
You run 3000 m on a cooper ~approx fitness level is 54 (mmol O2) / kg.
Now you loose 10 Lbs (5 kg), we assume no difference in the oxygen uptake.
Thus your fitness level will go from 54 to 56 (54*90/85).
It will give you a distance of 3150 m on 12 min.
Difference in speed is going from 4:10 min/km to 3:50 min/km or roughly
4 sek/km pr. kg.
I have seen litterature suggest 2-3 sek/km pr. kg.
Re: Lose weight, save how much time in 5K [GoJohnnyGo] [ In reply to ]
GoJohnnyGo wrote:
Brilliant
8+ years later I wonder what PedalHead things about carbon shoes.
