Problem with zipp valve extender
Im using the valve extender that comes with my zipp 404s. At first, the air keep leaking when I use the pump.. So I put teflon tape and made the seal good, and now I can pump the tube ONLY when I start with very low PSI (like 20 psi).
So for example, If I pump a tube, I have to first let most the air out, and then I can start pumping to any desired PSI .. Then I remove the pump head... Lets say the next day, I want to pump the tube back to 115 psi.. I have to take the air back down to 20PSI in order to pump. If I dont do that, the air just wont go in..
Anyone have this same problem? Any fixes or am I doing something wrong.
Re: Problem with zipp valve extender [125mph] [ In reply to ]
if you're using 404's save yourself the headache of using valve extenders in the first place and just buy tubes with 80mm valves and then you'll never have to worry about it.
_ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _
Michael in Fresno
"Do you spend time with your family? Good. Because a man that doesn't spend time with his family can never be a real man" V. Corleone
I don't care for those extenders. Actually, I think they suck. You can either buy tubes with the 80mm valves (can be pricey), or get a decent set of extenders where you remove the valve core of a standare 48mm tube.
Lock out the valve core fully open. Teflon tape. Good. To. Go.
Worst case, save yourself the trouble & get a Topeak/Vittoria extender with external valve core, eliminates the issue.
Re: Problem with zipp valve extender [Tribato] [ In reply to ]
WHAT? That might cost.....shit man.....$16.00! Damn Bro, he just spent a thousand or two on wheels and now you want him to spend SIXTEEN DOLLARS on tubes? /pink
Re: Problem with zipp valve extender [Record10Carbon] [ In reply to ]
I HATE HATE HATE valve extenders.
did I say I hate them???
just buy the 80mm tubes.
The ones with the internal valve core are trash. Switch to the integrated ones from Zipp/Vittoria/Topeak (need tubes that you can remove the valve core --> conti/qtubes are good)
I've never had a problem with these: http://zipp.com/.../detail.php?ID=16716
I gave up using valve extenders on my 404's, I don't care how good it looks, it just isn't worth the hassle. Buy 80mm valve tires, trust me the extra $$ for the longer valves is worth it!!
Now, I have to use valve extenders on my 808, but I only use it when I'm racing.
"Though she be but little, she is fierce" ~Shakespeare | Powered by HD Coaching | 2014 Wattie Ink Triathlon Team | Facebook | Instagram | Twitter
Re: Problem with zipp valve extender [KyraMorgan] [ In reply to ]
Cool, I'll get the 80mm valves. I dont care about the extra few dollars.. I thought it wasnt good for the tubes or something.
